To begin integrating Google Blogger and LinkedIn, first, you need to access Pabbly Connect. Open a new tab in your browser and navigate to the Pabbly Connect website. If you’re a first-time user, sign up for a free account to receive 100 free tasks each month.
Once logged in, you can start creating your automation setup. This process will allow you to automatically share your blog posts from Google Blogger to your LinkedIn profile without manual intervention. With Pabbly Connect, you can streamline your workflow and ensure your audience stays updated.
In this step, you will set up the trigger to monitor new posts on Google Blogger. In your Pabbly Connect dashboard, select “Google Blogger” as your trigger application and choose the event “New Post Added”. This will allow Pabbly Connect to detect when a new blog post is published.
- Click on the “Connect” button to establish a connection with your Google account.
- Select the appropriate Google account that manages your Blogger posts.
- Choose the blog ID and set the status to “Live” to capture only published posts.
After setting these parameters, click on the “Send Test Request” button. This action will allow Pabbly Connect to fetch the latest post data from your Google Blogger account, ensuring the integration works correctly.
3. Configuring the Action Step to Share on LinkedIn
Next, you will configure the action step to share the new blog post on LinkedIn. In your Pabbly Connect setup, select “LinkedIn” as your action application and choose the event “Share an Article or URL”. This step is crucial as it allows Pabbly Connect to post the content directly to your LinkedIn profile.
Click on the “Connect” button and log into your LinkedIn account to authorize Pabbly Connect. After the connection is established, you will need to map the fields for the LinkedIn post:
- In the “Content” field, write a brief description of your new vlog.
- Map the title and URL of your blog post from the previous step.
Once you have filled in these fields, click on the “Send Test Request” button to verify that the post is shared correctly on your LinkedIn profile. This ensures that the connection between Google Blogger and LinkedIn via Pabbly Connect is functioning as intended.
4. Testing the Integration Between Google Blogger and LinkedIn
After configuring both the trigger and action steps, it’s time to test the integration. Publish a new blog post on your Google Blogger account. For example, you can create a post titled “10 Everyday Outfit Ideas for Effortless Style” and publish it.
Once the post is live, return to your Pabbly Connect dashboard and click on the “Test Request” button. This will allow Pabbly Connect to check for the new blog post and share it on LinkedIn. Refresh your LinkedIn profile to see the newly created post, confirming that the integration works seamlessly.
This testing phase is crucial as it ensures that your audience on LinkedIn will receive updates whenever you publish new content on Google Blogger, enhancing engagement across platforms.
5. Conclusion: Automate Your Blogging Process with Pabbly Connect
In conclusion, using Pabbly Connect to integrate Google Blogger and LinkedIn allows you to automate the sharing of your blog posts effortlessly. By following the steps outlined in this tutorial, you can ensure that every new post reaches your LinkedIn audience without the hassle of manual sharing.
This not only saves you time but also enhances your content visibility across different platforms. Start using Pabbly Connect today to streamline your blogging workflow and keep your audience engaged with fresh content!
