To start automating your business reports, the first step is to access Pabbly Connect. Simply open a new tab and type in pably.com. Once on the Pabbly website, you can sign up for a free account or log in if you already have one.
Upon logging in, navigate to the Pabbly Agentic AI dashboard. This is where you can create workflows that will connect Google Sheets with Gmail for automated reporting. Click on “Create Workflow” to begin setting up your automation.
In this section, you will create a workflow named “CEO Reports” using Pabbly Connect. This workflow will help you automate the reporting process by fetching data from Google Sheets and sending it via Gmail.
  • Click on “Create Workflow” and name it.
  • Set up the trigger to monitor your Google Sheets for new sales data.
  • Configure the action to send an email summary via Gmail.
This setup will allow you to receive daily reports automatically, ensuring you never miss important data insights.
3. Fetching Data from Google Sheets
The next step involves configuring Pabbly Connect to fetch data from your Google Sheets. This is crucial for generating accurate reports based on your sales data.
In your workflow, specify the Google Sheet you want to pull data from. You will need to provide the link to your sheet and the specific tab name where your sales data is stored. This information allows Pabbly Connect to access and analyze the correct data.
  • Enter the Google Sheets link in the provided field.
  • Specify the tab name (e.g., “Sheet1”).
  • Confirm the data retrieval settings to ensure accuracy.
Once the data is successfully fetched, Pabbly Connect will prepare to generate your report.
4. Sending Email Reports via Gmail
After fetching data, the next step is to configure Pabbly Connect to send email reports using Gmail. This process is straightforward and ensures that you receive timely updates on your business performance.
In the email settings, specify the recipient’s email address and the subject line for your report. You will also need to set up your Gmail SMTP settings to enable sending emails from your account. This involves generating an app password from your Google account security settings.
  • Enter your Gmail address and the app password.
  • Set the email subject to something like “Daily Sales Report”.
  • Draft the email body to include key performance metrics.
This setup ensures that you receive a complete summary of your sales activities directly in your inbox.
5. Setting Up Scheduling for Reports
The final step in your automation process is to set up a schedule using Pabbly Connect. This allows your reports to be sent automatically at a specified time, making it easier to keep track of your business performance.
You can configure the scheduling option to send the reports daily at a specific time, such as 10 AM. This ensures that you receive your reports consistently without any manual effort.
To set up scheduling:
  • Choose the frequency (daily, weekly, etc.).
  • Specify the exact time for sending the report.
  • Save the scheduling settings.
This automated scheduling feature ensures that you never miss an important report, making your workflow efficient and effective.
By using Pabbly Connect, you can efficiently automate the process of generating and sending business reports using Google Sheets and Gmail. This integration allows for seamless data management and timely insights, enhancing your business decision-making.
