To start automating your Pinterest pins from a WordPress blog, the first step is accessing Pabbly Connect. You can do this by visiting the Pabbly Connect website at pabby.com/connect. Once you arrive, you can either sign in or sign up for a free account, which grants you 100 free tasks each month.
If you are a new user, click on the “Sign Up Free” button. Existing users should click “Sign In”. After signing up, you will be redirected to the workflow page, where you can create your automation.
The next step involves setting up a trigger in Pabbly Connect. This trigger will initiate the automation process whenever a new blog post is published on your WordPress site. In the workflow page, select “WordPress” as your trigger application.
  • Choose the event as “New Post Published”.
  • Click on the “Connect” button to generate a webhook URL.
Now, you will need to configure this webhook URL in your WordPress settings to complete the connection. This will allow Pabbly Connect to receive data from your WordPress site whenever a new post is published.
3. Configuring WordPress to Work with Pabbly Connect
To link WordPress with Pabbly Connect, you need to install the WP Webhooks plugin. Go to your WordPress dashboard, navigate to the “Plugins” section, and search for “WP Webhooks”. Install and activate the plugin.
Once the plugin is activated, go to the settings and select “WP Webhooks”. Here, you can set up the trigger by selecting “Post Created” as the event. Add the webhook URL you copied from Pabbly Connect and save the settings. This setup will ensure that every time a new post is created, the data will be sent to Pabbly Connect.
4. Creating a Pinterest Pin from WordPress Post
Now that the trigger is set, the next step is to create a Pinterest pin using the data fetched by Pabbly Connect. After publishing a new blog post, go back to the Pabbly Connect workflow and choose “Pinterest” as your action application.
  • Select “Create Pin” as the action event.
  • Connect your Pinterest account by clicking on “Add New Connection”.
  • Map the image URL and title from the WordPress post to the respective fields in Pinterest.
After mapping the fields, click on “Save and Send Test Request”. This will send the data to Pinterest and create a new pin automatically. You can verify the pin by checking your Pinterest account.
5. Conclusion: Automate Your Pinterest Marketing with Pabbly Connect
In this tutorial, we demonstrated how to automate the process of creating Pinterest pins from your WordPress blog using Pabbly Connect. By following the steps outlined, you can save time and effort while enhancing your marketing strategy.
With Pabbly Connect, you can seamlessly integrate various applications, allowing for efficient automation of your business tasks. This not only saves time but also helps in scaling your marketing efforts effectively.
Start using Pabbly Connect today to streamline your workflows and enhance your productivity. Don’t miss out on the opportunity to automate your marketing tasks effortlessly!
