To start automating your Instagram leads to Airtable, you need to access Pabbly Connect. Go to the Pabbly Connect homepage by entering the URL pabbly.com/connect. Here, you will see options to sign in or sign up.
If you are a new user, click on “Sign Up Free” to create an account. This will give you access to 100 free tasks every month. Existing users can simply log in to their accounts. Once logged in, you’ll be ready to create your automation workflow.
After logging into Pabbly Connect, click on the “Create Workflow” button. Here, you can use the Quick Builder, which simplifies the process of integrating applications. Enter the prompt “Integrate Instagram Lead Ads with Airtable” to begin.
- Select “New Lead Instant” as the trigger.
- Choose “Create Record” as the Airtable action.
- Click “Approve and Create” to finalize your workflow setup.
Your new workflow is now set up, connecting Instagram Lead Ads to Airtable seamlessly through Pabbly Connect.
3. Connecting Instagram Lead Ads to Pabbly Connect
In this step, you will connect your Instagram Lead Ads to Pabbly Connect. Click on the “Add New Connection” button for Instagram Lead Ads. You will be prompted to log into your Facebook account, which must be linked to your Instagram account.
Once logged in, select the Facebook page associated with your Instagram account. Choose the specific form from which you want to receive leads. Make sure to select the response format as “Simple” for easier data handling.
To ensure the integration works, you need to perform a test submission. Navigate to the Meta for Developers page and use the Lead Ads Testing Tool. Here, select your page and form, and delete any previous leads to avoid conflicts.
- Click on “Preview Form” to fill out the Instagram Lead Ads form.
- Submit the form with test details like email, first name, last name, phone number, and city.
Once submitted, return to Pabbly Connect to check if the response is received from Instagram Lead Ads. You should see the data populated in real-time, confirming that the integration is successful.
5. Mapping Data to Airtable via Pabbly Connect
After receiving the lead data, you will map it to Airtable. Select the Airtable action in Pabbly Connect and connect to your Airtable account. Choose the base where you want to store the lead data.
Next, you will map the lead fields from Instagram to Airtable. For example, map the first name, last name, email, phone number, and city. This mapping ensures that data is dynamically inserted into the correct fields in Airtable.
- Select the corresponding fields in Airtable.
- Click “Save and Send Test Request” to verify the data transfer.
After performing the test, check your Airtable base to see if the lead information has been successfully added. This confirms that the integration is fully operational through Pabbly Connect.
Using Pabbly Connect, you can automate the transfer of Instagram leads to Airtable efficiently. This step-by-step guide shows how to set up the integration seamlessly, saving you valuable time and effort.
