To start tracking petty cash, access Pabbly Connect by visiting pabbly.com. This platform serves as the central hub for your integrations.
Once on the site, you can either log in if you are a current user or sign up for a free trial. After logging in, navigate to the Pabbly Connect dashboard where you can initiate your integration process.
2. Building the Cashy App Using Pabbly Studio
The next step involves creating your application, Cashy, using Pabbly Studio. This tool allows you to build applications without coding.
Click on “Create App” and name it “Cashy.” In the description, specify that you need an app for managing petty cash expenses. Pabbly Studio will guide you through the setup process.
- Provide a detailed description of features needed.
- Include elements like a dashboard, expense tracker, and team section.
- Submit the request to generate your app.
Once submitted, Pabbly Studio will create your Cashy app, ready for use in tracking your petty cash.
3. Tracking Expenses with Cashy
After building Cashy, it’s time to track your petty cash expenses efficiently using Pabbly Connect. Open the app and navigate to the dashboard.
Here, you can add expenses quickly. For example, if you spent 1000 rupees on coffee and snacks, enter the details such as the category and payment method. This will help in keeping a clear record of all transactions.
- Select “Add Expense” and input the details.
- Fill in the amount, category, and date of the expense.
- Save the entry to update your cash balance.
This process ensures that you never lose track of your petty cash again, thanks to the seamless integration provided by Pabbly Connect.
4. Requesting Reimbursements through Cashy
With Cashy, you can also manage reimbursements effectively using Pabbly Connect. To request a reimbursement, navigate to the reimbursement section of the app.
Fill out the form with the necessary details such as the amount and category. This allows for easy tracking of who owes you money and for what purpose.
- Select the employee’s name and enter the reimbursement amount.
- Choose the appropriate category for the expense.
- Submit the request for processing.
This feature ensures that all your petty cash transactions are documented and processed efficiently through Pabbly Connect.
5. Conclusion
In conclusion, using Pabbly Connect to integrate Cashy allows for efficient tracking of petty cash. You can easily manage expenses and reimbursements without losing track.
This system not only simplifies financial management but also enhances accountability in your office. Start using Pabbly Connect today to streamline your petty cash tracking!
