To automate lead engagement, the first step is to set up Pabbly Connect. Begin by visiting the Pabbly Connect website and creating a free account to access 100 free tasks. This allows you to explore and test workflows without any cost.
Once you are logged in, navigate to the dashboard. Here, you will find the option to create a new workflow. Click on the ‘Create Workflow’ button, which will direct you to set up your first automation.
2. Creating a Workflow with Typeform and Gmail
In this section, we will create a workflow that triggers an email response through Gmail whenever a new Typeform submission occurs. This is where Pabbly Connect shines as the integration platform.
To start, click on ‘Create Workflow’ and select ‘Typeform’ as your trigger application. Choose the event as “New Entry”. Follow these steps:
  • Select Typeform as the trigger application.
  • Choose “New Entry” as the event.
  • Connect your Typeform account by clicking on ‘Add New Connection’.
After successfully connecting your Typeform account, select the specific form you want to use for this integration. Ensure that the response format is set to simple to capture individual details effectively.
3. Testing the Integration with Pabbly Connect
After setting up the Typeform trigger, it’s crucial to test the integration to ensure everything works correctly. This step involves submitting a test form to capture responses through Pabbly Connect.
Fill out the Typeform with sample data, including your name, email, and any other required fields. Once submitted, return to Pabbly Connect and check for the captured response. If successful, you should see the details populated in the Pabbly Connect interface.
  • Submit the Typeform with test data.
  • Verify that the response is captured in Pabbly Connect.
This confirmation indicates that the trigger is functioning as intended, paving the way for the next steps in the workflow.
4. Setting Up Gmail to Send Automated Responses
With the Typeform trigger confirmed, the next step is to set up Gmail to send automated emails. This process is seamlessly managed through Pabbly Connect.
Click on the Gmail application in your workflow and select “Send Email” as the action event. Connect your Gmail account by clicking on ‘Add New Connection’. After successful authentication, fill in the email details:
  • Set the sender name and email address.
  • Use mapping to insert the recipient’s email from the Typeform response.
  • Craft a personalized email subject and body.
This setup ensures that every lead receives a tailored welcome email immediately after their submission, enhancing engagement.
5. Finalizing Your Workflow in Pabbly Connect
After configuring the Gmail action, it’s time to finalize your workflow in Pabbly Connect. Click on the “Save and Send Test Request” button to send a test email to the recipient.
Check your Gmail inbox to confirm that the email was sent successfully. If everything looks good, your automation is now complete. From now on, every time a new entry is submitted via Typeform, a personalized email will be sent automatically, improving your lead engagement.
This automation not only saves time but also enhances professionalism in your communications, allowing you to focus on nurturing leads further.
In this tutorial, we explored how to automate lead engagement using Pabbly Connect to integrate Typeform and Gmail. By following these steps, you can ensure immediate responses to your leads, enhancing your business’s professionalism and efficiency.
