To start sending bulk messages on WhatsApp, first, you need to access Pabbly Connect. This platform enables you to integrate various applications seamlessly, including WhatsApp.
Simply go to the Pabbly Connect website and sign up for a free account. Once you log in, you can explore the features available for managing your WhatsApp business number effectively.
2. Setting Up Pabbly Chartflow for WhatsApp
After logging into Pabbly Connect, you will need to set up Pabbly Chartflow, which is essential for managing WhatsApp conversations. Navigate to the Pabbly Chartflow section to begin.
Here are the steps to set up Pabbly Chartflow:
- Create a new account or log in.
- Access the dashboard and navigate to the WhatsApp settings.
- Add your WhatsApp number and verify it.
This setup allows you to manage your WhatsApp messages efficiently and prepare for bulk messaging campaigns.
3. Creating a WhatsApp Message Template in Pabbly Chartflow
To send bulk messages, you must first create a message template using Pabbly Connect. Go to the template section in Pabbly Chartflow and click on the ‘Add Template’ button.
Follow these steps to create your template:
- Select the category, such as Marketing.
- Name your template and choose the language.
- Enter the body of the message and any interactive actions required.
Once your template is created, it will be sent for approval to Meta, and you will see its status in your dashboard. Make sure to wait for the approval before proceeding to send messages.
4. Sending Bulk WhatsApp Messages Using Pabbly Connect
Now that your template is approved, you can send bulk WhatsApp messages through Pabbly Connect. Navigate to the broadcast section and create a new broadcast campaign.
Here’s how to send bulk messages:
- Select the broadcast type and name your campaign.
- Choose your audience from the contact list.
- Select the message type as preapproved template.
Once you have set everything up, you can either send the message immediately or schedule it for a later time. This flexibility allows you to reach your audience effectively at the right moment.
5. Testing and Scheduling Your Broadcasts
Before sending out your bulk messages, it’s essential to test the broadcast using Pabbly Connect. This ensures that everything looks perfect for your audience.
To test your broadcast, follow these steps:
- Enter a test user’s phone number and click on the ‘Send Test Message’ button.
- Check the message formatting and content on your WhatsApp.
After testing, you can schedule the broadcast for a specific date and time or send it immediately. This ensures that your promotional messages reach your audience at the right moment, maximizing engagement.
In conclusion, using Pabbly Connect allows you to integrate WhatsApp effectively for sending bulk messages. This tutorial guides you through the process, ensuring you can promote your business without any hassle. Start leveraging the power of Pabbly Connect today to enhance your marketing efforts on WhatsApp!
