To start automating WhatsApp messages, you need to access Pabbly Connect. This platform allows seamless integration between various applications like LinkedIn and WhatsApp.
If you’re a new user, visit Pabbly’s website and sign up for an account. After signing up, you will receive 100 free tasks every month, perfect for testing your workflows. Existing users can log in directly to access the dashboard.
Once you are on the Pabbly Connect dashboard, you need to create a new workflow. Simply click on the “Create Workflow” button. You will see options to create from scratch, using AI, or a quick builder. For this integration, select the “Quick Builder” option.
  • Select the prompt for your workflow, such as “Reach LinkedIn leads on WhatsApp”.
  • Choose LinkedIn as the trigger application.
  • Set the trigger event to “Lead Notifications”.
After selecting the options, you will be prompted to approve the workflow. Click on “Approve and Create” to finalize the setup.
3. Linking LinkedIn with Pabbly Connect
In this step, you will connect LinkedIn to Pabbly Connect. Click on the application field and select LinkedIn. If you don’t have an existing connection, choose the option to create a new one.
After clicking the “Connect with LinkedIn” button, follow the sign-in process. Once signed in, select your LinkedIn account and click on “Save and Send Request”. This action will set up a webhook response waiting for new leads.
4. Sending Messages via Pabbly Chatflow
Now that your LinkedIn is connected, it’s time to integrate Pabbly Chatflow. Select it as the action application in your workflow. This tool will help send WhatsApp messages automatically to new leads.
  • Click on the “Connect” button to establish a connection with Pabbly Chatflow.
  • You will need an API token from your Pabbly Chatflow dashboard.
  • Map the WhatsApp mobile number field with the phone number received from LinkedIn.
After mapping, enter the message you want to send. You can customize this message with the lead’s first name for personalization.
5. Testing and Enabling Your Workflow
After setting up your workflow in Pabbly Connect, it’s crucial to test it. Click on “Save and Send Test Request” to verify that everything is functioning correctly. You should receive a confirmation message indicating success.
Finally, ensure to enable the workflow toggle so that it operates automatically. This way, you can send WhatsApp messages to leads even while you sleep, ensuring timely follow-ups.
This tutorial demonstrated how to integrate WhatsApp with LinkedIn using Pabbly Connect and Pabbly Chatflow. By following these steps, you can automate your messaging process effortlessly, enhancing your business communication.
