1. Setting Up Pabbly Connect for LinkedIn Integration
Pabbly Connect is the central platform for integrating LinkedIn with various applications. To start, access Pabbly Connect by visiting their website and signing up if you haven’t already. Once signed in, you will be greeted by the dashboard where you can create a new workflow.
Click on the “Create Workflow” button on the right-hand side. Name your workflow to reflect its purpose. This step is crucial as it helps you identify your automation later. After naming, you will be directed to the workflow builder where you can set up your trigger.
2. Linking LinkedIn to Pabbly Connect
To link LinkedIn with Pabbly Connect, select LinkedIn as your trigger application. Choose the event as “Lead Notification”. Click on the “Connect” button to establish a connection.
- Select your LinkedIn account.
- Authorize Pabbly Connect to access your account.
- Choose the specific LinkedIn ad account you want to connect.
After the connection is made, click on “Save and Send Test Request”. This will initiate a waiting state for a webhook response. You must submit a test lead through your LinkedIn ad to proceed.
3. Using OpenAI to Generate Responses
Once the LinkedIn integration is set, the next step is to utilize OpenAI for generating personalized responses. Select OpenAI as your next application in Pabbly Connect. For the event, choose “Generate Response Using Text Input”.
To connect OpenAI, click on the “Connect” button. You will need to input an API key from your OpenAI account. Generate this key by visiting your OpenAI dashboard and creating a new secret key. After copying the key, paste it in the Pabbly Connect interface.
- Select the model as GPT-4.
- Input a prompt for generating personalized messages.
Finally, map the lead’s name received from LinkedIn to personalize the response. Click on “Save and Send Test Request” to check if OpenAI generates the expected message.
4. Sending Messages via WhatsApp Using Pabbly Connect
The next application in your workflow is Chatflow, which is used to send messages to WhatsApp. In this step, select Chatflow as your application in Pabbly Connect. Choose the action to send a text message.
To connect Chatflow, click on the “Connect” button. If you do not have an existing connection, create a new one by entering your API token from your Chatflow account settings.
- Map the recipient’s WhatsApp number from the LinkedIn lead data.
- Input the generated message from OpenAI into the message field.
After completing these mappings, click on “Save and Send Test Request” to verify that the message is sent successfully to the lead’s WhatsApp account.
5. Creating Contacts in Salesforce CRM with Pabbly Connect
To wrap up your automation, the final application to integrate is Salesforce CRM. Select Salesforce as your action application in Pabbly Connect. Choose the action event as “Create Contact”.
Connect Salesforce by clicking on the “Connect” button. Authorize Pabbly Connect to access your Salesforce account. Once connected, you can map the lead data, including first name, last name, email, and phone number.
- Map the first name, last name, email, and phone number from LinkedIn.
- Click on “Save and Send Test Request” to create the contact.
After successfully creating the contact, refresh your Salesforce CRM to confirm that the new lead has been added. Ensure that the toggle is enabled to keep your workflow active.
This tutorial showcased how to integrate LinkedIn, OpenAI, and Salesforce CRM using Pabbly Connect. By automating these processes, you can ensure timely responses to leads and streamline your CRM management effectively.
