To send unlimited WhatsApp broadcasts, start by accessing Pabbly Connect. Visit Pabbly.com/chatflow in your browser to reach the homepage of Pabbly Chatflow.
If you are a new user, click on “Sign Up for Free” to create an account. Existing users can simply log in. Pabbly Connect is crucial as it facilitates the integration of WhatsApp with your marketing tools.
2. Creating a WhatsApp Message Template
Next, create a message template in Pabbly Connect. This template will be used for your broadcasts. Navigate to the template section, where you can see existing templates.
- Select “Add Template” to create a new message.
- Input the necessary details including the message content and any images.
- Ensure the template is approved by Meta to use for broadcasts.
Once created, you can use this template for sending bulk WhatsApp messages effortlessly through Pabbly Connect.
3. Setting Up the WhatsApp Broadcast
Now, proceed to set up your WhatsApp broadcast using Pabbly Connect. Click on the “Add Broadcast” button to begin the process. You will need to fill in the broadcast campaign name and select the contacts you wish to include.
To select contacts:
- Choose from existing contact lists or upload a CSV file.
- You can refine your audience by excluding specific contacts.
Once the contacts are set, you can choose to use the pre-approved message template you created earlier, ensuring compliance with WhatsApp guidelines.
4. Testing Your Broadcast Message
Before sending out the full broadcast, it’s essential to test your message via Pabbly Connect. Click on the “Send Test Message” option. This allows you to preview how the message will appear to recipients.
Input your WhatsApp number to receive the test message. Check for accuracy in the content and layout, ensuring everything looks as expected. Once confirmed, you can proceed to schedule or send the broadcast.
5. Scheduling the WhatsApp Broadcast
The final step is to schedule your WhatsApp broadcast through Pabbly Connect. You have the option to send the message immediately or select a future date and time for sending.
When scheduling:
- Make sure to pick a future date and time to avoid sending it immediately.
- Click on “Add Broadcast” to finalize the scheduling.
After scheduling, you can track the broadcast status within your Pabbly Connect dashboard, ensuring all messages are delivered as planned.
Using Pabbly Connect, you can efficiently send unlimited WhatsApp broadcasts. This tutorial outlined the essential steps from accessing Pabbly Connect, creating message templates, to scheduling broadcasts. Simplifying your marketing communication has never been easier!
