To start integrating Pabbly, Google Sheets, and Gmail, you first need to access Pabbly Connect. This platform allows seamless automation without manual coding.
Visit the Pabbly website and sign up for a free account. Once logged in, navigate to the dashboard where you can create your workflow. Here’s how to get started:
- Click on “Create Workflow”.
- Choose “Create from Scratch” for a custom setup.
- Select the applications you want to integrate.
Now you are ready to build your workflow that automates sending birthday discount emails.
2. Setting Up the Scheduler in Pabbly Connect
In this step, you will set up a scheduler in Pabbly Connect to check daily for upcoming birthdays. This automation will run daily at your specified time.
To set up the scheduler, follow these steps:
- Select “Scheduler” as your trigger app.
- Set the frequency to “Every Day”.
- Choose the time you want the workflow to execute.
After setting this up, your workflow will automatically check every day for birthdays and proceed to the next steps.
3. Integrating Google Sheets with Pabbly Connect
Now, you will connect Pabbly Connect with Google Sheets to fetch customer details, including their names, emails, and birthdays.
Follow these steps to integrate:
- Choose Google Sheets as your action app.
- Select the “Fetch Row” action event.
- Connect your Google account by clicking on “Add New Connection”.
Once connected, you can specify which sheet to pull data from and set up the lookup for today’s date to match with the birthdays.
4. Sending Birthday Emails via Gmail
After fetching the birthday details, the next step is to send an email using Gmail through Pabbly Connect. This ensures that your customers receive their birthday discounts automatically.
Here’s how to set this up:
- Select Gmail as your action app.
- Choose the “Send Email” action event.
- Connect your Gmail account and allow access.
Fill in the email subject and body, using the mapped values from Google Sheets for personalization. This ensures each customer receives a tailored message on their special day.
5. Conclusion
By using Pabbly Connect, you can seamlessly automate birthday discount emails through Google Sheets and Gmail. This setup not only saves time but also enhances customer engagement.
Implementing this workflow will allow you to focus more on your business while ensuring your customers feel valued on their birthdays. Start using Pabbly Connect today to create more such automations!
