To start using Pabbly Connect for your WhatsApp broadcast campaigns, first, you need to access the platform. Visit Pabbly Connect and sign up if you’re not already a user. Once registered, you will receive 100 free credits each month, perfect for testing and exploring the platform.
After signing in, navigate to the Pabbly Chartflow dashboard. This is where you will manage your WhatsApp campaigns. Ensure that you have your WhatsApp number added to your account for seamless integration. Follow the instructions provided to set up your WhatsApp number correctly.
2. Adding Contacts to Pabbly Chartflow
Next, you need to add your customer contacts to Pabbly Connect. This can be done by navigating to the contacts section and clicking the “+ Add Contact” button. You can add contacts manually or choose to import them in bulk using a CSV file, which is the recommended method for efficiency.
  • Prepare your contact data in a CSV format, which can be created using Google Sheets or Microsoft Excel.
  • Ensure the CSV file adheres to the required format, including first name, last name, and phone number.
  • Upload your CSV file to Pabbly Chartflow, ensuring it doesn’t exceed the 50 MB size limit.
Once your contacts are uploaded, you can create a contact list for your broadcast campaign. This will simplify the process of sending messages to your customers effectively.
3. Creating a Broadcast Campaign in Pabbly Connect
With your contacts added, it’s time to create your broadcast campaign using Pabbly Connect. Click on the “+ Add Broadcast” button to start. You will need to select the type of broadcast and provide a name for your campaign. For example, you might name it “Test Broadcast” for testing purposes.
Next, select the contact list that you wish to send the broadcast message to. You can also refine your audience by excluding specific contacts or lists if necessary. Choose the message type, either a pre-approved template or a regular message, depending on your needs.
  • Select a pre-approved template if your 24-hour conversation window has expired.
  • Add any images or additional content to your message as required.
After setting up your broadcast details, you can proceed to send a test message to ensure everything is functioning correctly. This testing phase is crucial to confirm that your setup is correct before going live.
4. Scheduling and Sending Your Broadcast
Once your broadcast campaign is ready, you have the option to send it immediately or schedule it for later using Pabbly Connect. If you choose to schedule, select the desired date and time for the broadcast. For instance, you might want to set it for 30th June at 12:00 PM.
After selecting your scheduling options, click on the “+ Add Broadcast” button to finalize the setup. This feature allows you to reach thousands of customers on WhatsApp efficiently. Remember, you can always view the stats of your broadcasts to analyze their performance.
Utilizing the scheduling feature can significantly enhance your marketing efforts, allowing you to send messages at optimal times for your audience. This ensures that your promotions and updates are received when they are most likely to be seen.
5. Conclusion: Maximizing Your WhatsApp Reach with Pabbly Connect
In summary, using Pabbly Connect for your WhatsApp broadcast campaigns enables you to efficiently manage and reach your customer base. By following the steps outlined in this tutorial, you can easily upload contacts, create engaging broadcast messages, and schedule them for maximum impact.
Whether you are promoting a new product or sharing important updates, Pabbly Connect simplifies the process, saving you time and effort while enhancing your communication strategy. Start leveraging these features today to elevate your marketing efforts on WhatsApp.
