1. Accessing Pabbly Connect for Justdial Automation
To automate Justdial leads, first, access Pabbly Connect by opening your laptop and visiting PABLY.com. This is the main platform that facilitates the integration of Justdial with various applications.
Once on the site, click on the “Sign Up for Free” button located at the top right corner. This will allow you to create a free trial account on Pabbly, enabling you to explore its features for automating your Justdial leads.
After signing up, log in to Pabbly Connect and navigate to the dashboard. Click on “Create Workflow” to begin setting up your automation process. You can prompt the workflow with a name, such as “Justdial leads to Sheets” or any other relevant name.
- Choose Justdial as your trigger application.
- Select the trigger event for Justdial.
- Add Google Sheets as your action application.
By integrating Pabbly Connect with Justdial and Google Sheets, you can seamlessly transfer leads into your Sheets automatically. This step is crucial for managing leads effectively.
3. Configuring the Webhook URL for Justdial
To connect Justdial with Pabbly Connect, you will need a Webhook URL. This URL is essential for receiving lead details from Justdial. Copy the Webhook URL provided by Pabbly Connect and share it with your Justdial account manager.
Since Justdial does not allow users to add Webhook URLs directly through their interface, you must send this URL via email to Justdial support or your account manager. Once they add it to your account, you will start receiving lead details directly into Pabbly Connect.
4. Mapping Lead Details to Google Sheets
Once the Webhook is configured, you can start mapping your lead details to Google Sheets using Pabbly Connect. Open your Google Sheets and click on “Connect” to establish a connection. Sign in with your Google account to allow Pabbly Connect access.
- Select the spreadsheet where you want to store the lead details.
- Map the lead details from Justdial to the corresponding columns in Google Sheets.
This mapping process ensures that every time a lead is received, it is automatically populated in your specified Google Sheet, making lead management efficient and organized.
5. Sending WhatsApp Messages with Pabbly Chatflow
To enhance your lead management further, integrate Pabbly Chatflow within your workflow. This feature allows you to send WhatsApp messages to your leads automatically. After setting up the Google Sheets integration, add Pabbly Chatflow as an action step in your workflow.
Choose the event for sending WhatsApp messages and configure the message template you want to send. This integration ensures that your leads receive instant notifications, improving engagement and follow-up rates.
By following these steps, you can effectively automate Justdial leads using Pabbly Connect and Pabbly Chatflow. This automation not only saves time but also enhances your lead management process significantly. Start using Pabbly today to streamline your operations and improve your business efficiency.
