To begin integrating Instagram Lead Ads with HubSpot, first access Pabbly Connect. This platform allows you to automate workflows between various applications effortlessly. If you’re new, sign up on the Pabbly website to receive 100 free tasks each month, perfect for testing.
After signing up, you will land on the Pabbly Connect dashboard. Here, you can create and manage your automation workflows. Click on the “Create Workflow” button to get started. This is where the magic of automation begins.
In this section, we will create a workflow to sync Instagram Lead Ads with HubSpot CRM using Pabbly Connect. Choose the “Quick Builder” option for the fastest setup. Enter a prompt like “sync Instagram lead ads into HubSpot pipeline without latency” to generate the workflow.
- Select the trigger as “New Lead” from Instagram Lead Ads.
- Choose “Create Contact” as the action in HubSpot CRM.
- Click on the “Save” button to create the workflow.
After saving, you will see the workflow created successfully. This setup allows you to automate the process without manual input, ensuring efficiency in lead management.
3. Connecting Instagram Lead Ads and HubSpot CRM
Next, you need to connect your Instagram Lead Ads account to Pabbly Connect. Click on the Instagram application in your workflow and then hit the “Connect” button. If you’re adding a new connection, select the option to connect with Instagram Lead Ads.
Make sure your Instagram account is linked to Facebook. After clicking “Continue,” select the Facebook page associated with your Instagram account. Choose the lead generation form you created earlier, ensuring the response format is set to “Simple”. This will allow Pabbly Connect to receive the necessary data.
4. Testing the Connection with Pabbly Connect
To verify that the connection works, fill out the lead form on your Instagram Lead Ads. After submission, return to Pabbly Connect to check for a webhook response. The response should include the details entered in the lead form.
Ensure that the workflow is receiving data correctly. If successful, you will see all the details populated from the lead form. This step confirms that your setup is functioning as intended, allowing for seamless data transfer.
5. Mapping Data to HubSpot CRM
Now it’s time to map the data received from Instagram Lead Ads to your HubSpot CRM using Pabbly Connect. Click on the HubSpot application in your workflow and select the option to connect. Choose an existing connection or add a new one as needed.
Map the required fields such as first name, last name, and email address using the data received from the Instagram form. This is crucial for ensuring that each lead is accurately recorded in your HubSpot CRM. After mapping, click the “Save and Send Test Request” button to finalize the process.
Once you’ve completed the mapping, check your HubSpot CRM to confirm that a new contact has been created with the details from the lead form. This integration allows for efficient lead management without manual entry.
This tutorial demonstrated how to seamlessly integrate Instagram Lead Ads with HubSpot using Pabbly Connect. By automating this process, you can save time and manage leads more effectively. Start using Pabbly Connect today to streamline your workflows and enhance your business operations.
