To begin automating feedback analysis, first access Pabbly Connect by navigating to pabbly.com/connect. Here, you’ll find options to either sign in or sign up for a free account. If you’re new, click on the green button labeled ‘Sign Up for Free’ to create your account.
Once signed in, you’ll see a dashboard featuring multiple Pabbly applications. Among these, Pabbly Subscription Billing and Pabbly Email Marketing are notable for handling billing and email tasks. For our feedback automation, we will focus on Pabbly Connect as the central integration tool.
Next, let’s create a workflow in Pabbly Connect. Click on the ‘Create Workflow’ button, and choose the option to create using the Quick Builder. Name your workflow based on the applications you wish to connect, such as Google Forms, OpenAI, and Google Chat.
- Select Google Forms as the trigger application.
- Choose ‘New Response Received’ as the trigger event.
- Set OpenAI as the action application and select ‘Generate Text’.
- Lastly, choose Google Chat to send the message.
After selecting these options, approve the workflow to create it. This will set up the connections needed for automating feedback analysis through Pabbly Connect.
3. Linking Google Forms to Pabbly Connect
To link Google Forms to Pabbly Connect, copy the provided Webhook URL from your workflow. Next, open your Google Form and navigate to the Responses section. Here, you need to link the form to a Google Sheet to capture responses automatically.
- Select ‘Create New Spreadsheet’ to generate a new sheet for responses.
- Publish the form and submit a test response to capture data.
- Open the Google Sheet and ensure the timestamp and responses are recorded.
Once the Google Sheet is linked, you can set up the Pabbly Connect Webhook to automatically send data from Google Sheets to your workflow. This integration is crucial for ensuring that feedback data is processed seamlessly through Pabbly Connect.
4. Generating Feedback Summary Using OpenAI
With Google Forms linked to Pabbly Connect, the next step is to configure OpenAI for generating feedback summaries. In your workflow, select OpenAI as the action app and connect it using your API key. This allows Pabbly Connect to communicate with OpenAI and generate text based on feedback data.
Now, input the prompt for generating a summary. For example, you might write: “Analyze the customer feedback below and provide a one-line summary, maximum 20 words.” This prompt will guide OpenAI to generate concise summaries that are easy for your team to understand.
Make sure to map the feedback details from the previous step into your prompt. This dynamic mapping ensures that each new response generates a tailored summary, enhancing the effectiveness of your feedback analysis.
5. Sending Feedback to Google Chat
Finally, to send the generated feedback summary to your team, configure Google Chat in your workflow. Create a Chat Webhook URL by going to your Google Chat space, selecting ‘Apps and Integrations’, and adding a new webhook. This URL will allow Pabbly Connect to send messages directly to your Google Chat space.
- Paste the Chat Webhook URL into your Pabbly Connect workflow.
- Map the generated summary message from OpenAI to be sent as the chat message.
- Test the connection to ensure messages are sent correctly.
Once this setup is complete, every time feedback is submitted via Google Forms, your team will receive a concise summary in Google Chat, allowing for quick analysis and action. This integration showcases the power of Pabbly Connect in automating feedback processes.
In summary, using Pabbly Connect to automate feedback analysis with Google Forms and OpenAI significantly enhances team communication and efficiency. This streamlined process ensures that valuable feedback is analyzed and shared promptly, empowering your organization to make informed improvements.
