1. Accessing Pabbly Connect for WhatsApp Promotion
To promote your business on WhatsApp effectively, you first need to access Pabbly Connect. Start by visiting pably.com and navigating to the Chatflow section. If you are a new user, create your account by selecting the ‘Sign Up for Free’ option. You’ll receive 100 free credits to test the setup.
Once logged in, you can use Pabbly Connect to send promotional messages. This tool enables you to manage and broadcast messages efficiently to your customer base. Ensure you have your audience list ready to maximize the effectiveness of your campaign.
2. Setting Up a Broadcast in Pabbly Connect
To send bulk WhatsApp messages, you need to set up a broadcast in Pabbly Connect. Navigate to the Broadcast section and click on the ‘Add Broadcast’ button. Here, you will start by naming your broadcast campaign for easy identification.
  • Select the type of broadcast campaign you want to create.
  • Choose your audience from the contact list you have uploaded in Pabbly Connect.
  • Refine your audience if necessary by excluding specific contacts.
After setting up your audience, select the message type. You can either choose a pre-approved template or create a new message. This flexibility allows you to tailor your communication to your audience’s preferences.
3. Creating a Message Template in Pabbly Connect
Creating a message template is crucial for your WhatsApp promotional campaign using Pabbly Connect. Go to the Template section and create a new template by entering the required details. Remember, your template must be approved by Meta to be used for broadcasting.
To create a compelling template, include the following elements:
  • A catchy header image that grabs attention.
  • Clear and concise text that conveys your promotional message.
  • Ensure the template adheres to Meta’s guidelines for approval.
Once your template is ready and approved, you can use it to send messages through Pabbly Connect to your audience. This step is vital for ensuring your promotional message is well-received.
4. Scheduling Your Broadcast with Pabbly Connect
After creating your template, the next step is to schedule your broadcast using Pabbly Connect. You can choose to send the message immediately or schedule it for a future date and time. This feature allows for better planning and execution of your marketing strategy.
To schedule your broadcast, follow these steps:
  • Select the date and time when you want the message to be sent.
  • Click on ‘Create Broadcast’ to finalize your scheduling.
By scheduling your broadcasts, Pabbly Connect helps you automate your marketing efforts, ensuring that your promotional messages reach your audience at the optimal time for engagement.
5. Testing Your Broadcast Before Sending
Before sending out your scheduled broadcast, it’s essential to test it using Pabbly Connect. This ensures that the message appears correctly on WhatsApp and that there are no formatting issues. Testing helps verify that your promotional content is ready for your audience.
To conduct a test:
  • Enter your phone number to receive a test message.
  • Check if the message and image appear as intended.
Once you confirm that everything is working correctly, you can proceed with confidence to send out your promotional messages using Pabbly Connect. This final step ensures that your marketing efforts are effective and professional.
In this tutorial, we explored how to use Pabbly Connect to promote your business on WhatsApp by sending promotional messages. By following these steps, you can effectively reach your audience and enhance your marketing efforts without spending on ads. Start leveraging Pabbly Connect today for your promotional campaigns!
