To start creating WhatsApp broadcast campaigns, access Pabbly Connect by visiting pabbly.com/chatbot. This platform allows you to integrate various applications seamlessly.
Once you create an account, you will receive 100 free credits monthly to explore the features of Pabbly Connect. This is ideal for testing and setting up your campaigns effectively.
2. Creating Your First WhatsApp Broadcast Campaign
In this step, you will create a WhatsApp broadcast campaign using Pabbly Connect. On the dashboard, navigate to the broadcast feature on the left sidebar.
- Click on the plus add broadcast button.
- Select the broadcast type as “broadcast campaign”.
- Name your broadcast (e.g., “Makeup Offer”).
After naming your broadcast, you can select your audience. You can either choose existing contacts or upload a CSV file directly through Pabbly Connect.
3. Uploading CSV Contacts to Pabbly Connect
To upload contacts, you need to prepare a CSV file containing customer details. This can be done using Google Sheets or Excel. Ensure your CSV file includes first name, last name, and phone number.
After creating your CSV file, download it and upload it to Pabbly Connect. You can skip duplicate records and import the contacts seamlessly into your broadcast campaign.
4. Selecting Your Message Template for Broadcast
Now that your contacts are uploaded, it’s time to select a message template. This is crucial for effective communication with your audience using Pabbly Connect.
- Choose between a pre-approved template or a regular message.
- Select the appropriate WhatsApp template you created earlier.
Make sure to test your message by sending a test broadcast to check if everything is working as expected through Pabbly Connect.
5. Scheduling Your WhatsApp Broadcast Campaign
Finally, schedule your broadcast campaign using Pabbly Connect. You can set the date and time for when you want to send the broadcast.
Additionally, enable the automatic retry feature to resend messages to any contacts that fail to receive them. This ensures that your promotional messages reach your audience effectively.
In summary, using Pabbly Connect to create WhatsApp broadcast campaigns is straightforward. You can easily upload contacts, select templates, and schedule broadcasts to engage with your customers effectively.
