1. Accessing Pabbly Connect for WhatsApp Automation
To begin automating WhatsApp customer replies, you need to access Pabbly Connect. This platform allows you to integrate various applications seamlessly, including Pabi, So I, and Pavi.
Start by visiting the Pabbly Connect website. Once there, you can sign up for a new account or log in if you already have one. Pabbly Connect provides a user-friendly interface that simplifies the automation process.
2. Setting Up Your WhatsApp Chatbot Using Pabbly Connect
After logging into Pabbly Connect, navigate to the flow page of Pabi Chatflow. This is where you will create your WhatsApp chatbot. Begin by entering the URL for Pabi Chatflow: pabi.com/chatflow.
- Click on “Sign Up Free” if you are a new user to get 100 free credits.
- If you are an existing user, simply click “Sign In”.
Once you’re on the flow page, ensure you add your WhatsApp number to your Pabbly Chatflow account. This integration is crucial for automating responses to customer inquiries.
3. Creating the WhatsApp Chatbot Flow with Pabbly Connect
To create your WhatsApp chatbot, you will use various message and action blocks available in Pabbly Connect. Start by dragging and dropping a trigger node, which initiates the chatbot flow.
Set the trigger as a keyword match, entering “hello” as the keyword. This means that whenever a user sends “hello,” the chatbot will respond. Next, drag a message node to send a welcome message to the user.
- Create a button labeled “Travel Packages” for users to select.
- Connect this button to a list node that displays different travel packages.
By utilizing these nodes, you can create an interactive experience for users to explore travel options.
4. Customizing Travel Packages in Pabbly Connect
In this step, you will enhance the travel package options in your WhatsApp chatbot using Pabbly Connect. For each package, create custom fields to track user selections.
For example, label the first package as “Goa Getaway” and add additional packages like “Manali Adventure” and “Dubai Luxury Trip”. Each package should have a corresponding button for users to book the package.
- Add a custom field for each package to identify user selections.
- Include a booking button that prompts users for their travel dates and names.
By implementing these custom fields, you can personalize the user experience and collect necessary information efficiently.
5. Finalizing Your WhatsApp Chatbot with Pabbly Connect
Once you’ve set up your travel packages and booking process, it’s time to finalize your WhatsApp chatbot using Pabbly Connect. Ensure all nodes are correctly connected, and test the flow to confirm functionality.
After testing, don’t forget to save your chatbot flow. This will enable you to automate customer conversations effectively, allowing users to check services and book packages directly through WhatsApp.
With your chatbot live, customers can easily access information without visiting multiple websites, enhancing their experience with your business.
In this tutorial, we explored how to automate WhatsApp customer replies using Pabbly Connect. By integrating Pabi, So I, and Pavi, you can create an efficient system for handling customer inquiries and bookings. Start using Pabbly Connect today to enhance your customer interactions.
