1. Access Pabbly Connect to Set Up Automation
To begin automating payment confirmation messages, access Pabbly Connect by visiting the official website. If you are new, create a free account to get started. This account allows you to utilize 100 free tasks each month, which is essential for setting up your workflow.
Once logged in, you can navigate to the dashboard and click on the “Create Workflow” button. This process is crucial as it sets the stage for integrating Razer Pay with WhatsApp through Pabbly Connect. Make sure to have your Razer Pay account ready for the next steps.
The first step in your workflow is selecting Razer Pay as the trigger application. To do this, click on the plus button in Pabbly Connect and search for “Razer Pay” in the application list.
- Select “Payment Captured” as the event.
- Press the connect button to generate a webhook URL.
- Copy the webhook URL for later use in your Razer Pay settings.
After copying the webhook URL, go to your Razer Pay account settings and add this URL in the webhook section. This integration allows Pabbly Connect to receive real-time payment data whenever a transaction is completed.
3. Integrating WhatsApp to Send Confirmation Messages
Next, you will set up WhatsApp as the action application in Pabbly Connect. Click on the plus button again and search for “WhatsApp Cloud API” to select it as your action application.
For this integration, you need to create a new connection by providing your WhatsApp Business API token, phone number ID, and account ID. This information can be obtained from the Meta for Developers page. Once you have these details, paste them into Pabbly Connect to establish the connection.
- Map the recipient’s mobile number dynamically from the payment data.
- Craft a message template that includes the customer’s name, payment amount, and payment ID.
This setup ensures that every time a payment is captured through Razer Pay, a confirmation message is sent automatically via WhatsApp using Pabbly Connect.
4. Testing Your Workflow for Successful Integration
After setting up the trigger and action, it’s essential to test your workflow in Pabbly Connect. To do this, make a test purchase through your Razer Pay account. This will allow you to see if the webhook is receiving data correctly.
Once the test payment is completed, check your WhatsApp to confirm that the payment confirmation message was sent successfully. If the message appears as expected, your integration is working properly. You can then finalize and save your workflow in Pabbly Connect.
5. Conclusion: Automate Payments with Pabbly Connect
In conclusion, using Pabbly Connect to automate payment confirmation messages with Razer Pay and WhatsApp streamlines your communication process. This automation not only saves time but also enhances customer trust by providing immediate feedback on their transactions.
By following the steps outlined in this tutorial, you can create an efficient workflow that ensures every customer receives timely payment confirmations without manual intervention. Start using Pabbly Connect today to simplify your payment processes!
