To integrate WhatsApp with Facebook Lead Ads, start by accessing Pabbly Connect. Visit the Pabbly website by typing pabbly.com in your browser. Once there, you can sign in or create a new account if you are a first-time user.
After signing in, navigate to the Pabbly Connect dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. Name your workflow something relevant like “Stop Losing Real Estate Leads” and select a folder for organization.
2. Setting Up the Trigger with Facebook Lead Ads
In this section, you will set up the trigger for your workflow using Pabbly Connect. Choose Facebook Lead Ads as your trigger application. The trigger event you want to select is “New Lead Instant”. This means that every time a new lead is generated, the workflow will be activated.
To connect your Facebook account, click on “Connect” and follow the prompts to authorize Pabbly Connect. Once connected, you will need to select the specific Facebook page and lead form you are using. For instance, choose the page named “Prime Properties” and the corresponding lead generation form.
  • Select “New Lead Instant” as the trigger event.
  • Choose the correct Facebook page and lead form.
After entering this information, hit “Save” and then test the connection to ensure everything is set up correctly. This will allow Pabbly Connect to capture lead information automatically.
3. Sending WhatsApp Messages via Pabbly Chatbot
Next, you will configure Pabbly Connect to send WhatsApp messages using Pabbly Chatbot. Add a new action step and select Pabbly Chatbot as the application. For the action event, choose “Send Text Message”.
You will need to connect your Pabbly Chatbot account by following the prompts. Once connected, map the phone number and other details from the lead captured in the previous step. This ensures that the message is personalized and sent to the correct recipient.
  • Select “Send Text Message” as the action event.
  • Map the phone number and message details from the lead.
  • Ensure the message is personalized for each lead.
This setup allows Pabbly Connect to send immediate WhatsApp messages to new leads, enhancing your follow-up process.
4. Setting Up Follow-Up Messages
To keep your leads engaged, you can set up follow-up messages using Pabbly Connect. After sending the initial WhatsApp message, add a delay action step. Choose the delay duration, such as 7 days, before sending the next follow-up message.
Repeat this process to send additional follow-up messages after 30 days. Each follow-up message can be customized to check in with the lead and offer further assistance.
  • Add a delay step for 7 days after the initial message.
  • Customize the follow-up message for engagement.
  • Repeat for a 30-day follow-up message.
This feature of Pabbly Connect ensures that your leads receive timely reminders and personalized messages, keeping them in the loop.
5. Conclusion
By using Pabbly Connect, you can effectively automate your follow-up process with WhatsApp messages for Facebook Lead Ads. This integration streamlines communication and enhances lead engagement.
Utilizing these automated workflows not only saves time but also ensures that no lead is left unattended. Start leveraging Pabbly Connect today for efficient lead management!
