To get started with automating your lead management, access Pabbly Connect by visiting pabbly.com/connect. If you are a new user, click on the “Sign up for free” option to create your account. This will allow you to explore Pabbly Connect’s features through a free trial before deciding on a subscription plan.
Once logged in, you will be directed to your dashboard. Here, you can create workflows that connect various applications. This is crucial for seamless lead management, as Pabbly Connect enables integration between Google Ads and Google Sheets, allowing automatic data entry without manual effort.
After accessing your dashboard, click on the “Create Workflow” button. You can use the quick builder option to set up your workflow efficiently. For instance, if you’re looking to add lead details to a spreadsheet, name your workflow something like “Add Lead Details in Sheets”.
  • Select Google Ads as the trigger app since your leads will come from there.
  • Choose “New Lead Form Entry” as the trigger event.
  • Set Google Sheets as the action app to add new rows automatically.
Once you’ve set this up, click on “Approve and Create” to finalize your workflow. This step is essential as it lays the foundation for how Pabbly Connect will handle incoming leads.
3. Connecting Google Ads and Google Sheets
Next, you need to connect Google Ads to your Pabbly Connect workflow. Click on the connect button next to Google Ads in your workflow. You will see a webhook URL that you need to copy. This URL is crucial for linking your Google Ads lead form to the workflow.
Now, go to your Google Ads campaign and create a lead form. Make sure to include fields like name, email, phone, and city. In the lead delivery section, paste the webhook URL you copied from Pabbly Connect and enter the required key. After this, send test data to ensure everything is set up correctly.
4. Mapping Data in Google Sheets
Once the connection is established, it’s time to connect Google Sheets to Pabbly Connect. Click on the connect button for Google Sheets. If you have not created a connection before, select “Add a new connection” and sign in with your Google account.
After connecting, select the specific spreadsheet where you want to store your leads. For example, you might choose a sheet named “New Leads”. In the mapping section, you will need to map the fields from Google Ads to your Google Sheets. This means linking the name, email, phone number, and city fields directly to their corresponding columns in your spreadsheet.
  • Use the mapping feature in Pabbly Connect to dynamically insert data from the previous step.
  • Click on “Save and Send Test Request” to verify that the data is correctly added to your spreadsheet.
This mapping process is crucial as it ensures that every new lead from Google Ads is automatically added to your Google Sheets without any manual input.
5. Finalizing Your Automation with Pabbly Connect
After successfully mapping your data, you can finalize your automation. With Pabbly Connect, every new lead from Google Ads will now automatically populate your Google Sheets. This means no more tedious copy-pasting, allowing you to focus on other important tasks.
You can also expand your automation by integrating more applications, such as Facebook Lead Ads or Instagram Lead Ads. Pabbly Connect supports a variety of applications, making it a versatile tool for all your automation needs.
By following these steps, you can streamline your lead management process and enhance productivity. This automation not only saves time but also reduces the chances of errors associated with manual data entry.
In summary, using Pabbly Connect to automate your lead management can significantly enhance efficiency. By integrating Google Ads and Google Sheets, you can eliminate manual data entry and ensure accurate lead tracking. Go and try this amazing automation to simplify your workflow today!
