1. Accessing Pabbly Connect for AI Agent Training
To begin training your AI agent, access Pabbly Connect. This platform is essential for integrating various applications like OpenAI and Pabbly Chatbot.
Once you log in, navigate to the Pabbly Connect dashboard. Here, you can create workflows that connect the necessary applications. This tutorial will guide you through setting up your AI agent step by step.
2. Setting Up Your AI Agent in Pabbly Chatbot
Start by creating a new AI agent in the Pabbly Chatbot section. Click on the “Add AI Assistant” button to begin the setup process.
- Choose a name for your assistant, such as “Hotel Booking Assistant”.
- Select the type of instructions your assistant will follow.
- Adjust the temperature setting for response creativity.
After completing these steps, click on the “Add AI Assistant” button to save your settings. Your AI agent is now ready to be customized further.
3. Configuring AI Instructions and API Key
Once your AI agent is set up, the next step is configuring its instructions. This is crucial for how the AI responds to user queries. In Pabbly Connect, you can specify the instruction type.
For this tutorial, set the instruction type to “AI Agent”. Additionally, you will need to connect your OpenAI API key. Follow these steps:
- Go to your OpenAI API dashboard and create a new secret key.
- Copy the API key and paste it into the designated field in Pabbly Connect.
- Select the model type, such as GPT-4 Omni.
After pasting the API key, click on the “Connect” button. You should see a success message confirming the connection.
4. Uploading Knowledge Base for Your AI Agent
To enhance your AI agent’s capabilities, upload a knowledge base file. This file is crucial for providing accurate responses based on your business information.
In Pabbly Connect, navigate to the Knowledge Base section and click on “Add New File”. You can upload files in .txt or .pdf format. Ensure your file contains relevant information for your AI agent.
- The file size should be less than 90 MB.
- If using a PDF, it should not exceed 10 pages if it contains images.
After uploading, click on “Insert” to finalize the process. Your AI agent is now equipped with a knowledge base for effective communication.
5. Finalizing Your AI Agent Setup in Pabbly Connect
With all configurations complete, it’s time to finalize your AI agent setup. In Pabbly Connect, you can customize the chat interface, including the title and welcome message.
Adjust the design elements to match your brand, and ensure that your AI agent is activated. Click on the “Save AI Assistant” button to complete the setup.
Now, your AI agent is ready to assist customers effectively. Remember to test its responses to ensure it meets your business needs. Pabbly Connect simplifies the entire process, making it easy to integrate multiple applications seamlessly.
This tutorial has guided you through the process of training an AI agent using Pabbly Connect. By integrating OpenAI and Pabbly Chatbot, you can create a powerful assistant for your business needs.
