To start using Pabbly Connect, first, log in to your Pabbly account. This platform acts as the central hub for integrating various applications including Pabbly, OpenAI, and BuildCraft.
After logging in, navigate to the Pabbly Connect dashboard. You will see options to create new workflows. This is where you can set up the integration of your applications seamlessly.
2. Creating Your WhatsApp Assistant with Pabbly Chatbot
Next, use Pabbly Connect to create an intelligent WhatsApp assistant. Click on the “Add Smart Assistant” button to begin. You will need to provide a name for your assistant, such as “BuildCraft Assistant”.
- Select the type of instruction as “AI Agent”.
- Adjust the temperature setting for response creativity.
- Choose the model provider as OpenAI.
Once you have selected these options, click on “Create Assistant” to finalize your setup. This step is crucial as it defines how your assistant will interact with users.
3. Configuring OpenAI API with Pabbly Connect
To connect your assistant to OpenAI, you need to configure the API key within Pabbly Connect. Go to the API keys section in your OpenAI account and generate a new secret key.
Copy the key and paste it into the designated field in Pabbly Connect. This links your assistant to OpenAI’s powerful AI capabilities, allowing for intelligent responses to user queries.
Make sure your OpenAI account is on a paid plan to generate the API key successfully. After saving your settings, you will see a confirmation message indicating that the connection was successful.
4. Uploading Your Knowledge Base for Enhanced Responses
Next, enhance your assistant’s capabilities by uploading a knowledge base. This is essential for providing accurate and relevant responses. Use Pabbly Connect to upload a PDF or a text file that contains all necessary information about your business.
- Ensure the file size is below 90 MB.
- Include all relevant business details in the document.
After uploading, your assistant will be able to use this information to provide accurate answers to customer inquiries, improving user experience significantly.
5. Finalizing Your WhatsApp Assistant Setup
Finally, finalize your WhatsApp assistant setup within Pabbly Connect. Customize the interface by adjusting the title, subtitle, and initial messages to align with your brand.
Don’t forget to activate your assistant by toggling the activation button. After saving your settings, you can embed the assistant into your website using the provided code snippet.
This integration allows your assistant to operate continuously, providing instant responses to customer queries while you focus on other tasks.
By following this tutorial, you can effectively use Pabbly Connect to integrate various applications and create an intelligent WhatsApp assistant. This setup enhances customer interaction and streamlines communication without manual effort.
