1. Setting Up Pabbly Connect for Your AI Assistant
To create your AI assistant for WhatsApp, you first need to access Pabbly Connect. This platform allows you to integrate various applications seamlessly. Start by logging into your Pabbly account and navigating to the Pabbly Connect dashboard.
Once in the dashboard, you will find options to create a new workflow. Click on the “Create Workflow” button and give your workflow a suitable name, such as “WhatsApp AI Assistant Integration”. This step is crucial as it sets the foundation for connecting OpenAI and other applications.
2. Creating Your AI Assistant with Pabbly Chatbot
Next, you will utilize the Pabbly Chatbot feature within Pabbly Connect. Click on the option to add a new AI assistant. You will see a prompt to name your assistant. Enter a name like “Home Nursing AI Assistant” and click the “Add AI Assistant” button.
Now, you need to select the type of instructions for your assistant. Choose the option labeled “AI Agent”. This selection will automatically generate the necessary instructions for your assistant. Make sure to customize these instructions based on your business needs.
- Select the temperature setting for AI responses.
- Choose OpenAI as your AI service provider.
- Select the version of OpenAI you want to use.
After setting these parameters, you will proceed to configure the API key, which is essential for linking your assistant with OpenAI.
3. Configuring the OpenAI API Key
To connect your AI assistant to OpenAI, you will need an API key. This is facilitated through Pabbly Connect. Navigate to the OpenAI API keys section and create a new secret key. Once generated, copy this key for use in Pabbly.
Return to your Pabbly Connect workflow and paste the API key in the designated field. Click on the “Connect” button to establish the link between your OpenAI account and your AI assistant. This integration is crucial for enabling your assistant to respond to customer inquiries effectively.
Ensure that your OpenAI account is active and has a paid subscription, as this is a requirement for generating the API key. After a successful connection, your assistant will be ready to process queries using AI.
4. Uploading the Knowledge Base for Your AI Assistant
The next step in creating your AI assistant involves uploading a knowledge base. This is a critical component as it provides the information your assistant will use to respond to customer queries. In Pabbly Connect, you can upload a document containing all relevant business information.
Click on the option to “Add New File” and select your knowledge base document. This can be a PDF or text file with a size limit of 90 MB. After uploading, ensure the file is correctly linked to your assistant.
- Use Google Docs or any text editor to create your knowledge base.
- Ensure the document contains all essential information about your services.
- Check the file size before uploading to avoid errors.
Once your knowledge base is uploaded, your AI assistant will be equipped to handle inquiries accurately based on the information provided.
5. Final Settings and Activation of Your AI Assistant
After setting up your AI assistant, you will need to configure the final settings in Pabbly Connect. This includes setting up automatic response rules for your assistant. Navigate to the settings section and enable the option for your assistant to respond to chats automatically.
You can customize the welcome message, fallback message, and retry attempts for the assistant. Make sure to save all changes before exiting the setup. This ensures that your assistant is fully functional and ready to assist customers on WhatsApp.
Once everything is set, you can activate your AI assistant and start using it to interact with customers. This integration not only streamlines communication but also enhances customer satisfaction.
Creating your own AI assistant for WhatsApp is made easy with Pabbly Connect. This tutorial walks you through the essential steps, from setting up your assistant to integrating it with OpenAI. By following these steps, you can enhance your business communication and provide timely responses to customer inquiries.
