1. Accessing Pabbly Chatflow for Integration
To start integrating Pabbly, Google, Google Sheets, and Excel, you first need to access Pabbly Chatflow. This platform allows you to create WhatsApp marketing campaigns efficiently.
Once you log into your Pabbly account, navigate to the Pabbly Chatflow dashboard. Here, you will find the options to set up your messaging campaigns, including the broadcast feature that is essential for bulk messaging.
2. Creating a New Campaign in Pabbly Chatflow
Creating a new campaign is straightforward in Pabbly Chatflow. Click on the ‘Add Broadcast’ button to initiate your campaign setup.
  • Select the broadcast type as ‘Broadcast Campaign’.
  • Name your broadcast, for example, ‘Grocery Store Offer Alert’.
  • Choose your audience by selecting either ‘Choose Existing Contact List’ or ‘Upload a CSV File’.
After selecting your audience, you can refine it based on specific criteria. This allows for targeted messaging, ensuring that only the relevant contacts receive your promotional messages.
3. Uploading CSV Files for Audience Selection
In Pabbly Chatflow, uploading a CSV file is essential for managing your audience effectively. You can create this file using Google Sheets or Excel, ensuring it contains customer details such as first name, last name, and phone number.
Make sure your CSV file meets the required specifications. Here are the key points to remember:
  • The maximum file size allowed is 50 MB.
  • You can upload up to 200,000 contacts at once.
  • Ensure the CSV format is correct to avoid upload errors.
Once your CSV is ready, simply upload it in Pabbly Chatflow to finalize your audience selection for the campaign.
4. Scheduling Your Messages in Pabbly Chatflow
Scheduling messages is a crucial feature in Pabbly Chatflow. After crafting your message, you can choose to send it immediately or schedule it for a later date and time.
To schedule a message, select the date and time you want the message to be sent. For example, you might choose to send your message on October 26th at 4:50 PM. This flexibility allows you to plan your marketing efforts strategically.
Additionally, you can enable automatic retries for failed contacts. This ensures that your messages reach as many customers as possible, enhancing the effectiveness of your campaign.
5. Testing Your Campaign Before Launch
Before launching your campaign, it is essential to test it using Pabbly Chatflow. You can send a test message to yourself or a test contact to verify that everything works as expected.
To conduct a test, input a test contact name and phone number, then click on the ‘Send Test Message’ button. This step is crucial for ensuring that your broadcast message appears correctly in WhatsApp.
After confirming the test message is received successfully, you can proceed to launch your marketing campaign, confident that it will reach your audience effectively.
In conclusion, using Pabbly Chatflow for integrating Pabbly, Google, Google Sheets, and Excel simplifies the process of creating effective WhatsApp marketing campaigns. With its features, you can easily manage contacts, schedule messages, and test your campaigns for optimal results.
