1. Introduction to Pabbly Connect for Onboarding
Pabbly Connect is an excellent platform for automating your onboarding processes. By using Pabbly Connect, you can streamline communications and eliminate repetitive tasks associated with onboarding new employees or customers.
This tutorial will guide you through the steps to create an automated onboarding workflow using Pabbly Connect, integrating Typeform for form submissions and Gmail for email notifications.
2. Setting Up Your Workflow in Pabbly Connect
To start, log into your Pabbly Connect dashboard. Click on the ‘Create Workflow’ button located on the right side of the dashboard.
  • Select ‘Create using Quick Builder’
  • Enter a prompt such as “Create a workflow where Typeform entries trigger a Gmail email”
  • Approve the workflow structure generated by Pabbly Connect
After setting up the workflow, you will need to integrate Typeform and Gmail within Pabbly Connect to complete the onboarding automation.
3. Integrating Typeform with Pabbly Connect
To integrate Typeform, navigate to the Typeform application in Pabbly Connect. Click on the ‘Connect’ button to establish a connection.
  • Choose ‘Add New Connection’
  • Sign in to your Typeform account
  • Select the form you want to use for capturing responses
Ensure the response format is set to ‘Simple’ to capture individual responses effectively. Save the settings and send a test request to verify the integration.
4. Sending Emails via Gmail through Pabbly Connect
Next, you will need to integrate Gmail to send emails automatically to new joiners. Open the Gmail application in your Pabbly Connect workflow.
  • Press ‘Connect’ and choose ‘Add New Connection’
  • Sign in with your Google account
  • Map the recipient email using the data from Typeform
Fill in the email subject and body, including any necessary details about the joining documents. Once completed, save and send a test email to ensure everything is functioning correctly.
5. Finalizing and Testing Your Pabbly Connect Workflow
After integrating both Typeform and Gmail, it’s time to finalize your workflow. Review all settings and ensure that the data mappings are correct.
Test the entire process by submitting a sample entry through your Typeform. Check your Gmail to confirm that the email is received with the correct information. This step is crucial to ensure your onboarding automation is working seamlessly.
With Pabbly Connect, your onboarding process is now automated, allowing for efficient communication with new employees without manual intervention.
In this tutorial, we explored how to automate your onboarding process using Pabbly Connect, integrating Typeform and Gmail effectively. This automation not only speeds up onboarding but also enhances communication efficiency.
