To automate sharing Instagram posts to Discord, you first need to access Pabbly Connect. Open a new tab in your browser and type in pab.com/connect. After pressing Enter, the Pabbly Connect landing page will appear.
If you are a new user, click on the “Sign Up for Free” button to create an account, which allows you to create up to 100 free tasks each month. Existing users can simply click on the “Sign In” button to access their dashboard.
Once logged into Pabbly Connect, you will see the dashboard where you can create a new workflow. Click on the “Create New Workflow” button. You can either create from scratch or use the quick workflow builder.
  • Select “Create Workflow” option.
  • Name your workflow to reflect its purpose, like “Connect Instagram for Business with Discord”.
  • Click on “Create” to proceed.
Your workflow will be set up to trigger whenever a new media post is made on your Instagram account. This is how Pabbly Connect facilitates the automation process effectively.
3. Connecting Instagram and Discord via Pabbly Connect
Next, you will connect your Instagram account to Pabbly Connect. Click on the “Connect” button and choose “Add New Connection”. Select “Connect with Instagram for Business” from the options presented.
Once you click on this option, you will be prompted to log into your Instagram account. After logging in, click on “Continue” to establish the connection. This will allow Pabbly Connect to monitor your Instagram account for new posts.
4. Setting Up Discord Webhook for Notifications
To send messages to Discord, you need to set up a Webhook URL. Go to your Discord channel, click on the settings, and navigate to the Integrations section. Here, you can create a new Webhook.
  • Select “Create Webhook” and name it appropriately.
  • Copy the Webhook URL provided by Discord.
Paste this URL back into Pabbly Connect to set up the connection. This Webhook will be used to post messages to your Discord channel whenever a new Instagram post is made.
5. Finalizing the Automation Process
Once you have set up both connections, you can draft the message that will be sent to Discord. Use the mapping feature to automatically insert the permalink and media URL from Instagram into your message.
After drafting your message, click on “Save and Send Test Request” to test the workflow. This will ensure that every time a new Instagram post is made, the details will be posted to your Discord channel through Pabbly Connect.
In this tutorial, we explored how to use Pabbly Connect to automatically share Instagram posts to Discord. By following these steps, you can streamline your social media management and enhance community engagement effortlessly.
