To start integrating Pabbly Chat Flow with Pabbly, you first need to access Pabbly Connect. Open your browser and visit the Pabbly Connect website. After signing up, you can begin the integration process.
Once logged in, you will find the dashboard. This is where you will manage your integrations. Make sure to familiarize yourself with the interface as it will guide you through the steps to set up your WhatsApp menu sharing.
2. Setting Up Pabbly Chat Flow
To create a seamless menu-sharing experience, you will utilize Pabbly Connect to set up Pabbly Chat Flow. Start by navigating to publy.com/chatflow and signing up for a free trial. This tool will allow you to generate a QR code for your café’s menu.
- Select the country code and enter your mobile number.
- Write the message that customers will receive when they scan the QR code.
- Customize the QR code’s appearance, including colors and logos.
After generating the QR code, you can download it and place it on your restaurant tables. This allows customers to scan the code and receive your menu directly through WhatsApp, enhancing their experience.
3. Adding WhatsApp Number in Pabbly Chat Flow
Next, you need to configure your WhatsApp number in Pabbly Connect. Log into your Pabbly Chat Flow account and open the dashboard. Ensure that you add the same WhatsApp number that you used for the QR code.
To add your WhatsApp number, click on the ‘Add WhatsApp Number’ button. This step is crucial, as it links your WhatsApp account to the Pabbly Chat Flow for seamless communication.
- Navigate to the Flow section from the left panel.
- Click on ‘Add Flow’ to create a new workflow for your menu sharing.
- Name your flow, for example, ‘QR Flow’.
Once you have set up the WhatsApp number, you can proceed to define the trigger event for your flow, ensuring that it activates when the appropriate message is received.
4. Configuring the Trigger Event in Pabbly Connect
After setting up your WhatsApp number, the next step in Pabbly Connect is to configure the trigger event. This is essential for the automated response when customers scan the QR code and send a message.
Choose ‘Keyword/Regex Match’ as your trigger event. This means that when a customer sends a specific message, the workflow will be activated. Copy the message you previously wrote for the QR code and paste it into the trigger field.
Now, you can add the menu to be sent automatically. In the Actions section, select the Media button. This will allow you to attach the menu file, whether it’s an image, document, or video. Upload your menu file from your computer and insert it into the flow.
5. Finalizing Your Pabbly Connect Workflow
To finalize your workflow in Pabbly Connect, you need to save the flow and test it. Make sure to click on the save button after you have configured all settings and added the menu file.
After saving, you can test the flow by scanning the QR code and sending the predefined message. You should receive the menu as a response, confirming that your integration is successful. This automation provides a streamlined experience for your customers.
By following these steps, you have successfully integrated Pabbly Chat Flow with Pabbly using Pabbly Connect. This setup not only enhances customer interaction but also automates the menu distribution process.
In this tutorial, you learned how to integrate Pabbly Chat Flow with Pabbly using Pabbly Connect. This process enables seamless WhatsApp menu sharing, enhancing customer experience in your café.
