1. Setting Up Pabbly Connect for WhatsApp Auto Replies
To set up 24/7 WhatsApp auto-replies, you need to access Pabbly Connect. Start by opening your browser and navigating to the Pabbly Connect website.
After signing up for an account, you’ll land on the Pabbly Connect dashboard. Here, you will integrate your WhatsApp number with Pabbly Connect, which is essential for enabling auto-replies.
2. Integrating Pabbly Chat Flow with WhatsApp Auto
Once you have set up your account, the next step is to integrate Pabbly Chat Flow with WhatsApp Auto. This integration allows you to create an AI assistant that responds to customer inquiries.
  • Select the AI Assistant option from the left menu.
  • Click on the button to create a new assistant.
  • Follow the prompts to configure your assistant’s settings.
Integrating Pabbly Chat Flow with WhatsApp ensures that your assistant is ready to handle inquiries 24/7, enhancing customer engagement.
3. Configuring Your AI Assistant in Pabbly Connect
With Pabbly Connect, you can easily configure your AI assistant. Start by selecting the AI instructions tab and customizing the parameters for your assistant.
Set the temperature for the AI responses, which affects the creativity of the replies. A temperature of 0.5 is often ideal for balanced responses.
  • Choose OpenAI as your AI provider.
  • Enter your API key to connect OpenAI with your assistant.
  • Adjust settings for header, footer, and fallback messages.
This configuration allows your assistant to provide personalized replies based on your business needs, showcasing the power of Pabbly Connect.
4. Setting Up the Knowledge Base for Your Assistant
Your AI assistant needs a knowledge base to provide accurate information. In Pabbly Connect, you can upload your business details in text or PDF format.
To do this, navigate to the knowledge source tab and upload your knowledge base file. This file serves as the brain of your AI assistant, allowing it to respond effectively.
  • Click on the add new file button in the media library.
  • Select your file and confirm the upload.
  • Ensure the file is correctly linked to your assistant.
By setting up a solid knowledge base, you enhance the effectiveness of your Pabbly Chat Flow assistant, ensuring it provides accurate and relevant answers to customer queries.
5. Finalizing and Activating Your AI Assistant
After configuring your assistant and knowledge base, the final step is to activate it. In Pabbly Connect, enable the assistant toggle to make it live.
Once activated, your assistant will be ready to respond to WhatsApp messages. You can also embed it on your website by selecting the embed option and copying the provided code.
With Pabbly Connect, you can ensure that your business is always available to answer customer inquiries, enhancing customer satisfaction and engagement.
By following this tutorial, you can set up 24/7 WhatsApp auto-replies using Pabbly Connect and Pabbly Chat Flow. This integration helps you provide timely responses to your customers, improving your business’s overall efficiency.
