1. Accessing Pabbly Connect for Bulk Messaging
To start sending your Meta product catalog to customers in bulk, you first need to access Pabbly Connect. This platform allows you to automate the process without any coding skills. Simply visit the Pabbly Connect website and log in or sign up for a free account.
Once logged in, you can create integrations that connect your Meta product catalog with WhatsApp. This connection is crucial for sending bulk messages efficiently. Make sure you have your WhatsApp number ready to proceed with the setup.
2. Creating a Contact List in Pabbly Connect
The next step involves creating a contact list within Pabbly Connect. This list will include all the customers you wish to send your product catalog to. Navigate to the contact management section and start adding contacts manually or upload a CSV file with customer details.
- Go to the contact management section in Pabbly Connect.
- Click on ‘Add Contact’ to input customer details.
- Alternatively, upload a CSV file for bulk addition.
After creating your contact list, ensure that it is saved correctly. This list will be used for sending the bulk WhatsApp messages containing your product catalog.
3. Creating a Message Template for the Catalog
In order to send your product catalog, you need to create a message template in Pabbly Connect. This template will serve as the foundation for your WhatsApp messages. Go to the template section and click on ‘Add Template’.
Fill out the required fields, including selecting the category as “Marketing” and naming your template. Make sure to include the catalog link and a call-to-action button like “View Catalog”. After submission, your template will be sent for approval to Meta.
4. Sending Bulk WhatsApp Messages Using Pabbly Connect
Now that you have your contact list and message template ready, it’s time to send bulk WhatsApp messages. Use the broadcast feature in Pabbly Connect to initiate this process. Click on ‘Add Broadcast’ and select the type as “Broadcast Campaign”.
- Name your broadcast (e.g., “Catalog Message”).
- Select your audience from the contact list.
- Choose the pre-approved template message you created earlier.
Before finalizing, you can send a test broadcast to ensure everything looks good. This feature allows you to see how the message will appear to your customers. Once satisfied, schedule or send the broadcast immediately.
5. Scheduling Your Broadcast with Pabbly Connect
If you wish to send your catalog message at a later date, Pabbly Connect allows you to schedule your broadcast. When setting up the broadcast, you will find an option to select the date and time for sending the message.
Choose your desired date and time, then confirm the scheduling. Your message will be sent automatically at the specified time, ensuring your customers receive the product catalog when you want them to.
In this tutorial, we explored how to use Pabbly Connect to send your Meta product catalog to customers in bulk via WhatsApp. By following these steps, you can efficiently reach out to your customer base and promote your products effectively.
