1. Accessing Pabbly Connect for WooCommerce and HubSpot Integration
To start automating your WooCommerce store with HubSpot, first access Pabbly Connect by visiting pabbly.com/connect. Here, you can easily create workflows that connect your applications.
If you are a new user, click on “Sign Up Free” to create an account and get 100 free tasks every month. Existing users can simply log in. Once logged in, navigate to your dashboard to begin creating your automation.
2. Creating an Automation in Pabbly Connect
In your Pabbly Connect dashboard, click on the “Create Workflow” button to start. This is where you will set up the integration between WooCommerce and HubSpot.
- Click on “Create Using Quick Builder”.
- Enter your prompt: “Integrate WooCommerce and HubSpot”.
- Select “New Order Created” as the trigger from WooCommerce.
After setting the trigger, choose “Create Contact” as the action for HubSpot. Click “Approve” to finalize your selections and proceed to the workflow page.
3. Setting Up Webhook for WooCommerce
In the workflow page of Pabbly Connect, you will see a Webhook URL. This URL is crucial for connecting WooCommerce to Pabbly Connect.
Copy the Webhook URL and go to your WordPress account. Under the WooCommerce settings, navigate to the “Advanced” tab and select “Webhooks”. Here, you will add a new webhook.
- Click on “Add Webhook”.
- Name it “Customer Data” and set it to active.
- Paste the copied Webhook URL and click “Save Webhook”.
Once saved, this webhook will help capture customer data when an order is placed in your WooCommerce store.
After setting up the webhook, return to Pabbly Connect to test if the integration is working. Click on “Recapture Webhook Response” to fetch the latest order details.
Now, go back to your WooCommerce store and place a test order for a product. Fill in the required customer details during checkout and complete the order.
- Ensure you provide a valid email and customer information.
- Select a payment method and confirm the order.
Once the order is confirmed, check back in Pabbly Connect to see if the order details have been captured successfully. This confirms that the integration is functioning correctly.
5. Creating a Contact in HubSpot
After confirming that the order details are captured, proceed to create a contact in HubSpot. In Pabbly Connect, select the “Connect with HubSpot” option.
Choose your HubSpot account and authorize the connection. You will then see various fields to fill in for the contact. Instead of entering details manually, utilize the mapping feature of Pabbly Connect.
- Map customer details like email, first name, last name from WooCommerce.
- Select the appropriate fields to ensure data accuracy.
Once all necessary fields are mapped, click on “Save and Send Test Request”. Check your HubSpot account to verify that the new contact has been created successfully.
By using Pabbly Connect, you can seamlessly automate the process of adding WooCommerce customers to HubSpot. This integration not only saves time but also ensures that your customer database is always up-to-date.
Start utilizing Pabbly Connect today to enhance your business automation and streamline your CRM processes effectively.
