To start using Pabbly Connect for your integration needs, first navigate to Pabbly Connect by visiting pabbly.com/chatflow. This platform serves as the central hub for connecting various applications seamlessly.
If you are a new user, click on the “Sign Up Free” button to create an account. For existing users, simply log in to your account. Once logged in, you will see various options, including Pabbly Chat Flow, which is essential for our WhatsApp broadcasting process.
2. Setting Up Pabbly Chat Flow
After accessing Pabbly Connect, select the “Access Now” button under Pabbly Chat Flow. This will take you to the dashboard where you can manage your WhatsApp broadcasts.
Here, you can link your WhatsApp number within your Chat Flow account. To do this, follow these steps:
  • Click on “Settings” to add your WhatsApp number.
  • Verify your number through the verification process.
  • Once verified, you can start using your number for broadcasts.
After linking your number, you can create a message template that will be used for your broadcasts. This is crucial for the next steps in the process.
3. Creating Broadcasts with Pabbly Connect
To create a broadcast using Pabbly Connect, navigate to the “Broadcast” section on your dashboard. Here, you can see the total number of broadcasts, live broadcasts, and scheduled ones.
To initiate a new broadcast, click on the “Add Broadcast” button. From there, select the broadcast type as “Campaign” and name your campaign. After naming it, you will choose your audience, either from existing contacts or by uploading a CSV file from Google Sheets.
  • If using existing contacts, select the desired list.
  • For CSV uploads, download your Google Sheets data as a CSV and upload it here.
  • Click on “Import” to create a separate contact list.
Once your audience is set, you can customize your broadcast further by excluding certain contacts if needed, ensuring your message reaches the right people without spamming others.
4. Sending and Testing Your Broadcast
Before sending the broadcast, you can test it. In the broadcast setup, you will find an option to test your message. This is crucial to ensure that everything works correctly before sending it out to your entire audience.
To test, select a different WhatsApp number you own and send the test message. Once you send it, you will receive a confirmation that the test was successful. This step ensures that your message appears correctly formatted and that links or images are functioning as intended.
  • Ensure your message template is approved by Meta to avoid delivery issues.
  • Check for any errors in the message before sending it out to the main audience.
After testing, you can proceed to schedule your broadcast or send it immediately based on your preferences. This feature allows you to manage your messaging effectively, maximizing engagement with your audience.
5. Tracking Broadcast Results in Pabbly Connect
Once your broadcast is sent, you can track its performance directly within Pabbly Connect. This feature provides valuable insights into how your messages are being received.
You will see statistics such as the number of messages sent, delivered, read, and failed. This data is crucial for analyzing the effectiveness of your campaigns and making adjustments for future broadcasts.
  • Review delivery rates to gauge audience engagement.
  • Identify any issues with message delivery to specific contacts.
By monitoring these metrics, you can refine your approach and improve future broadcasts, ensuring that your messaging strategy remains effective and engaging for your audience.
In this tutorial, we explored how to effectively use Pabbly Connect for sending WhatsApp broadcasts through Pabbly Chat Flow. By following these steps, you can automate your messaging and reach your audience efficiently. This integration not only saves time but also enhances your communication strategy.
