1. Accessing Pabbly Chatflow for Integration
To start integrating WhatsApp with your Shopify store, you first need to access Pabbly Chatflow. Begin by visiting pabby.com/connect in your browser. This will direct you to the Pabbly homepage, where you can either sign up for a new account or log in if you are an existing user.
Once logged in, you will see the dashboard where all Pabbly applications are listed. Click on “Access Now” under Pabbly Connect to proceed. This interface is crucial for setting up your automation to send WhatsApp messages for order confirmations.
2. Creating a Workflow in Pabbly Chatflow
In Pabbly Chatflow, creating a workflow is essential for automation. To do this, choose the “Quick Builder” option to set up your workflow. The workflow consists of a trigger and an action, where the trigger is the event that starts the automation.
  • Select the app as Shopify.
  • Choose the event as Order Creation.
  • Copy the generated webhook URL for further use.
After setting up the trigger, you are ready to connect your Shopify account with Pabbly Chatflow using the webhook URL. This connection is vital for receiving order details automatically.
3. Setting Up the Webhook in Shopify
Next, you need to set up the webhook in your Shopify account. Go to “Settings” and select “Notifications”. Here, you will find the option to create a new webhook. This is where you will paste the webhook URL copied from Pabbly Chatflow.
  • Select the event as Order Creation.
  • Choose JSON as the format.
  • Save the webhook to complete the setup.
Once the webhook is saved, it will be waiting for a response. You can test this by placing a test order in your Shopify store. This action will trigger the webhook and send the order details to Pabbly Chatflow.
4. Sending WhatsApp Confirmation Messages
After successfully setting up the webhook, the next step is to configure Pabbly Chatflow to send WhatsApp messages. In the workflow, you will need to add an action that specifies sending a WhatsApp message using the data received from the trigger.
To do this, you will enter the WhatsApp number you want to send the message to. Instead of manually entering customer details, you will map the data from the previous step. This ensures that each message is personalized with the correct order details.
  • Map the customer’s phone number and name from the trigger.
  • Compose a message that includes order details.
  • Click “Save and Send Test Request” to verify.
Once you send the test message, you should receive a confirmation on WhatsApp with the order details, demonstrating that the integration is successful.
5. Conclusion
In this tutorial, we explored how to integrate WhatsApp with Shopify using Pabbly Chatflow. The process involved creating a workflow, setting up a webhook, and sending personalized confirmation messages automatically. This integration not only saves time but also enhances customer communication.
By following these steps, you can easily set up automated WhatsApp messages for your Shopify orders, ensuring that your customers receive timely updates. Utilizing Pabbly Chatflow makes this process seamless and efficient.
