1. Setting Up Pabbly Connect for Your WhatsApp Campaign
Pabbly Connect is the central platform that enables you to integrate multiple applications for seamless workflows. To start, log in to your Pabbly account and navigate to the Pabbly Chatbot section. This is where you will create your WhatsApp broadcast campaign.
Once you are on the Pabbly Chatbot dashboard, locate the broadcast feature on the left sidebar. Here, you can manage and create your campaigns efficiently. Ensure you have your WhatsApp number added to Pabbly Chatbot for the integration to work.
2. Creating Your Broadcast Campaign Using Pabbly Connect
To create your broadcast campaign, click on the “+ Add Broadcast” button in Pabbly Connect. This will prompt you to select the type of broadcast campaign you want to create. Enter a name for your campaign, such as “Holiday Offer,” to keep things organized.
- Select the audience by choosing your contact list.
- Upload a CSV file with customer details for bulk messaging.
- Create personalized messages that will greet each customer by name.
After selecting your contacts, you can refine your audience by excluding specific contacts or lists. This ensures that your broadcast reaches only the intended recipients, enhancing the effectiveness of your campaign.
3. Personalizing Your Message in Pabbly Connect
The next step in Pabbly Connect is to personalize your broadcast message. Choose between a pre-approved template message or a regular message based on your needs. For this tutorial, we will use a pre-approved template message.
To create your message, use dynamic fields to personalize it. For example, you can include a greeting that automatically inserts the customer’s name by using the dollar symbol followed by the field name, like this: “$name”. This customization will make your messages feel more personal and engaging.
- Ensure your template follows WhatsApp guidelines and is approved by Meta.
- Test your message by sending a sample to ensure everything displays correctly.
Once you’ve set up your personalized message, you can proceed to the next step in your campaign.
4. Scheduling Your Broadcast with Pabbly Connect
With your message prepared, it’s time to schedule your broadcast. Pabbly Connect allows you to send your campaign immediately or schedule it for a later date. This flexibility ensures your message reaches customers at the optimal time.
To schedule your broadcast, select the desired date and time for delivery. For example, you can set it for July 28th at 6:50 PM. This feature is particularly useful for time-sensitive offers, ensuring they arrive when customers are most likely to engage.
Additionally, you can enable automatic retries for failed deliveries, selecting how many times and how long to wait between attempts. This ensures that your messages are delivered effectively, maximizing engagement.
5. Testing and Launching Your Campaign via Pabbly Connect
Before launching your broadcast campaign, it’s crucial to test it. Use the “Send Test Message” feature in Pabbly Connect to verify that your message is delivered correctly. This step allows you to see how the message will appear to your customers.
Upon testing, check your WhatsApp to confirm that the message has been received. Ensure that personalization works as intended, greeting each customer by their name. Once satisfied with the test results, you can finalize and launch your campaign.
After launching, monitor the campaign’s performance via Pabbly Connect. You can view delivery stats and make adjustments for future campaigns based on this data.
In this tutorial, we explored how to use Pabbly Connect to create personalized WhatsApp broadcast campaigns. By following these steps, you can efficiently reach your customers with tailored messages, enhancing engagement and boosting your business’s effectiveness.
