To start integrating Zoho CRM with WhatsApp, first access Pabbly Connect by visiting pabbly.com/connect. If you are a new user, sign up for a free account to get 100 free tasks.
Once logged in, navigate to the dashboard. Here, you will find the option to create a new workflow. This allows you to automate tasks without any coding skills, making it easy to manage your leads effectively.
Next, click on the “Create Workflow” option. You can opt to create using the AI feature, which simplifies the process. Enter your requirement, such as sending WhatsApp messages to new Zoho CRM leads automatically.
  • Select the trigger as “Zoho CRM” and the action as “WhatsApp Cloud API”.
  • Approve and create the workflow.
This setup allows you to receive notifications via WhatsApp whenever a new lead is added in your Zoho CRM account, streamlining your communication process.
3. Connecting Zoho CRM to Pabbly Connect
To connect your Zoho CRM account, click on the “Connect” option within the workflow. Enter your Zoho domain, which typically follows the format zoho.in for Indian users.
After saving the domain, grant the necessary permissions for Pabbly Connect to access your Zoho CRM data. This ensures that your information remains secure while allowing seamless integration.
4. Setting Up WhatsApp Cloud API in Pabbly Connect
Once Zoho CRM is connected, the next step is to set up the WhatsApp Cloud API. Click on the “Connect” button again and enter your WhatsApp API details, including the token and phone number ID.
To find these details, refer to the Pabbly forum page where tutorials guide you through setting up your WhatsApp Cloud API. This setup is essential for sending automated messages to your leads.
  • Generate a permanent token for your WhatsApp business account.
  • Copy and paste the token into your Pabbly Connect workflow.
Once the WhatsApp API is connected, you can proceed to map the lead’s phone number and message content, ensuring that the right information is sent to each new lead.
5. Testing Your Integration with Pabbly Connect
After setting up the connections, it’s crucial to test the workflow. Create a new lead in your Zoho CRM account, filling in all necessary details like name, email, and phone number.
Then, return to Pabbly Connect and click on the “Save and Send Test Request” button. This action captures the last lead created, allowing you to verify if the WhatsApp message is sent successfully.
Upon successful testing, you should see a WhatsApp message in your account welcoming the new lead. This confirms that the integration is functioning as intended, automating your lead notifications seamlessly.
In this tutorial, we have explored how to integrate Zoho CRM with WhatsApp using Pabbly Connect. By automating your lead notifications, you can enhance your communication efficiency and ensure timely responses to inquiries. This setup is a great way to streamline your business processes.
