To start integrating WhatsApp with Facebook leads, you need to access Pabbly Connect. Open your browser and search for pabbly.com/connect. This will take you to the Pabbly Connect homepage.
Once there, you have two options: either sign in if you are an existing user or click on ‘Sign Up Free’ to create a new account. Signing up gives you access to 300 tasks every month, allowing you to explore the software effectively.
After signing in, navigate to the dashboard of Pabbly Connect. Here, you can create a new workflow by selecting the ‘Create Workflow’ option. You can choose to build a workflow from scratch or use the AI Workflow Builder.
For this tutorial, we will use the AI Workflow Builder. Enter a description of your workflow, such as: “When a new lead comes in from Facebook, send a WhatsApp message.” This will help the AI understand your requirements.
- Select Facebook Lead Ads as the trigger app.
- Choose ‘New Lead’ as the trigger event.
- Connect your Facebook account to Pabbly Connect.
After setting up the trigger, you will see a preview of your workflow. Click on the ‘Create’ button to finalize your workflow setup in Pabbly Connect.
3. Setting Up WhatsApp Integration
Now that your workflow is created, it’s time to set up the WhatsApp integration. In the action step of Pabbly Connect, select ‘Pabbly Chatflow’ as the action app. This allows you to send WhatsApp messages seamlessly.
Next, choose the ‘Send Text Message’ action event. You will need to connect your Pabbly Chatflow account by entering the API token. You can find this token in your Pabbly Chatflow dashboard under the settings section.
- Enter your WhatsApp mobile number.
- Map the lead’s details from the previous step.
- Compose your personalized WhatsApp message.
Once you have filled in all the necessary details, click on the ‘Save and Send Request’ button. This will send a WhatsApp message to the new lead automatically through Pabbly Connect.
4. Testing Your Integration
After setting up your workflow, it’s crucial to test the integration. You can do this by generating a test lead in your Facebook Lead Ads. This will trigger the workflow you created in Pabbly Connect.
Check the Pabbly Connect dashboard for the response received. You should see the lead details captured and the WhatsApp message sent successfully. This confirms that your integration is working as intended.
Make sure to refresh your Facebook Lead Ads page and delete any previous test leads to ensure a clean test environment.
5. Conclusion
In this tutorial, we explored how to integrate WhatsApp with Facebook leads using Pabbly Connect. By automating the follow-up process, you can engage with leads instantly and efficiently. This integration enhances your communication strategy and ensures no lead is left unattended.
Utilizing Pabbly Connect for automating your workflows can significantly improve your business operations. Start leveraging this powerful tool today to streamline your communication with leads.
