To integrate WhatsApp with Facebook using Pabbly Connect, first, open a new tab and search for Pabbly Connect. You will find an option to sign up for free. Click on this button to enable your free trial.
Once you have signed up, log in to your Pabbly Connect dashboard. From here, navigate to the “Create Workflow” option and select “Create Using Quick Builder”. Enter “Facebook to WhatsApp” in the provided field to get started.
In this step, we will create a workflow that connects Facebook leads to WhatsApp messages using Pabbly Connect. After naming your workflow, you will be prompted to select the application that will send WhatsApp messages. Choose “Facebook Lead Ads” from the suggestions provided.
  • Select “Send Text Message” as your action.
  • Click on “Approve and Create” to finalize your workflow.
Your workflow is now set up. Next, you will need to connect your Facebook Lead Ads to Pabbly Connect.
To connect Facebook Lead Ads, click on the “Connect” button next to it in your workflow. Then, select “Add a New Connection” and choose “Connect with Facebook Lead Ads”. Ensure your Facebook account is logged in, or Pabbly will prompt you to log in.
After logging in, click on the “Continue” button to proceed. You will then need to select the specific page and form for which you want to create the automation. Once selected, click on “Save and Send Test Request” to test the connection.
Now that your Facebook Lead Ads are connected, the next step is to connect your WhatsApp application through Pabbly Connect. You will need to add a token for the WhatsApp connection. Follow the help text provided to obtain your token.
  • Select “Use Existing Connection” and enter your token.
  • Map the recipient’s WhatsApp number from the previous step.
This mapping allows the number to be dynamic, ensuring it updates with each new lead. Enter the WhatsApp message you wish to send, including dynamic fields like the lead’s name.
5. Testing the Integration
After setting up your WhatsApp message in Pabbly Connect, click on “Save and Send Test Request”. You will receive a confirmation that the message has been sent. Check your WhatsApp to see if the message has arrived correctly.
This confirms that your integration is successful. You can now automatically send WhatsApp messages to your leads received from Facebook using Pabbly Connect. If you have any questions or need further assistance, feel free to reach out in the comments section.
In this tutorial, we explored how to automate sending WhatsApp messages for Facebook leads using Pabbly Connect. This integration streamlines your communication process, ensuring timely responses to potential customers.
