To get started with integrating Pabbly, Pabbly Chat Flow, and Pabbly Chatbot, first, access Pabbly Connect by visiting pabbly.com. Once you create an account, you will be directed to the dashboard of Pabbly Connect.
On the dashboard, you will find various options for integration. The first step is to add your WhatsApp number to your Pabbly Chat Flow account. This is crucial for sending bulk messages effectively.
2. Creating a WhatsApp Broadcast Using Pabbly Connect
Using Pabbly Connect, you can easily create a WhatsApp broadcast to send messages to multiple customers simultaneously. Start by selecting “Broadcast” from the left sidebar. This will take you to the WhatsApp broadcast page.
- Select the type of broadcast campaign you want to create.
- Name your broadcast (e.g., “Clothing Offer”).
- Choose your audience from the contacts list created in Pabbly Chatbot.
After selecting your audience, you can refine your broadcast list by excluding certain contacts if needed. This feature helps ensure that your messages reach the right customers without redundancy.
3. Designing Your WhatsApp Message Template with Pabbly Connect
Next, you will design your WhatsApp message template using Pabbly Connect. To do this, navigate to the “Templates” section from the left menu. Here, you can create a new WhatsApp template that will be sent to your customers.
Once your template is approved by Meta, you can use it for your broadcast. You can upload images and customize the message to fit your promotional needs. This is a vital step to ensure that your broadcast is visually appealing and informative.
4. Sending and Scheduling Your Broadcast with Pabbly Connect
With your template ready, it’s time to send or schedule your broadcast using Pabbly Connect. You can choose to send the broadcast immediately or schedule it for a later date and time. For instance, you might want to send your message on September 21, 2026, at 7 PM.
- Select the option to send immediately or schedule for later.
- If scheduling, specify the date and time.
- Enable automatic retries for failed messages.
This functionality ensures that your messages are sent efficiently, and you can track the delivery status through Pabbly Connect’s dashboard.
5. Monitoring Broadcast Results with Pabbly Connect
After sending your broadcast, monitoring its performance is essential. With Pabbly Connect, you can easily check the statistics of your broadcast. This includes metrics like delivery rates, read status, and any failed messages.
By analyzing these metrics, you can optimize future broadcasts and ensure better engagement with your audience. Pabbly Connect provides comprehensive reports that help you understand how well your messages are performing.
In this tutorial, we explored how to use Pabbly Connect to integrate Pabbly, Pabbly Chat Flow, and Pabbly Chatbot for effective communication. By following these steps, you can efficiently send WhatsApp broadcasts to your customers and enhance your marketing efforts.
