To begin your integration process, access Pabbly Connect by visiting pabbly.com/connect in your browser. This platform is essential for connecting WhatsApp and Razer Pay seamlessly.
If you’re new to Pabbly, you’ll need to sign up for a free account. Existing users can simply sign in. Once logged in, navigate to the Pabbly Connect dashboard to start creating your workflow.
In the Pabbly Connect dashboard, you will create a new workflow. Click on the option to create a workflow from scratch. This step is crucial as it sets the foundation for your automation.
  • Select the AI workflow builder for a guided setup.
  • Enter a prompt stating your need: ‘When a payment is received on Razer Pay, send a WhatsApp message via Pabi Chatflow.’
  • Choose the Razer Pay trigger as ‘Payment Captured’ and the action as ‘Send Text Message’ in Pabi Chatflow.
After confirming your selections, proceed to approve and create the workflow. This initial setup is vital for enabling the automation to function properly.
3. Setting Up the Trigger for Razer Pay
Now, you need to set up the trigger in Pabbly Connect. This involves copying the webhook URL provided by Pabbly Connect. This URL will link your Razer Pay account to the automation.
Log in to your Razer Pay account and navigate to the developers’ section. Here, select the webhooks option and add a new webhook using the copied URL. Ensure you select ‘Payment Captured’ as the active event.
After saving the webhook, the connection between Razer Pay and Pabbly Connect is established. To test it, you will need to simulate a payment on your Razer Pay payment page.
4. Sending WhatsApp Messages via Pabbly Connect
Once the trigger is set, the next step is to configure the action that sends WhatsApp messages. In this step, you will use Pabbly Connect to connect with Pabi Chatflow.
  • Access your Pabi Chatflow account to retrieve your API token.
  • Paste the token into the Pabbly Connect setup.
  • Map the customer’s phone number and personalize the message with order details.
After configuring these settings, click on ‘Save and Send Test Request’ to verify that the WhatsApp message is sent successfully. This step confirms that the automation is functioning as intended.
5. Conclusion: Automate Your Payment Notifications
In this tutorial, we have successfully integrated WhatsApp and Razer Pay using Pabbly Connect. This automation allows you to send instant confirmation messages to customers upon receiving payments, enhancing communication and efficiency.
By following these steps, you can easily set up similar workflows to streamline your business processes. Automating notifications not only saves time but also improves customer satisfaction.
Utilizing Pabbly Connect for your automation needs can significantly enhance your operational capabilities. Start integrating today and experience the benefits!
