1. Accessing Pabbly Connect for WhatsApp Broadcasts
To begin using Pabbly Connect for sending WhatsApp broadcasts, first access the Pabbly Chatbot dashboard. This is crucial for integrating your WhatsApp number effectively. Simply search for Pabbly Connect in your browser and log into your account.
If you’re a new user, sign up for a free trial at Pabbly’s official site. This gives you 100 credits to explore the features of Pabbly Connect and send up to 100 WhatsApp messages without any cost. Once you’re logged in, you can start setting up your broadcasts.
2. Adding Your WhatsApp Number in Pabbly Connect
Adding your WhatsApp number in Pabbly Connect is essential for sending messages. Navigate to the dashboard, and find the option to add your WhatsApp number. Click on the ‘Add WhatsApp Number’ button, and input your number accurately.
  • Ensure your number is verified to avoid any issues.
  • You can find detailed tutorials in the description box if you need help.
Once added, your WhatsApp number will be ready for use in broadcasts. This step is crucial as it forms the backbone of your messaging strategy using Pabbly Connect.
3. Creating Your First WhatsApp Broadcast
To create a broadcast in Pabbly Connect, navigate to the broadcast feature on the left side of the dashboard. Here, you can view previous broadcasts or create a new one by clicking on the ‘Add Broadcast’ button.
When setting up your broadcast, select the type as “Broadcast Campaign” and name it appropriately, such as “Skin Care Test” for your skincare brand. Choose your contact list, which can consist of multiple contacts or just one, depending on your target audience.
  • Select the contacts you wish to send messages to.
  • You can refine your audience by excluding certain contacts.
This feature allows you to tailor your message delivery using Pabbly Connect, ensuring you reach the right audience effectively.
4. Personalizing Your WhatsApp Messages
Personalization is key when sending bulk WhatsApp messages through Pabbly Connect. Ensure that each message includes the recipient’s name for a more personal touch. To do this, use the dynamic value feature by entering the variable in your message.
You can also add buttons in your messages to direct leads to your website. This is done by creating a template in the message settings. Choose the template type, add your content, and include interactive buttons for actions like “Go to Website” or “Purchase Products”.
  • Use dynamic fields to customize messages for each contact.
  • Test your messages before sending to ensure everything works correctly.
This personalization feature in Pabbly Connect helps improve engagement rates and conversions.
5. Scheduling and Sending Your Broadcast
Once your message is ready, you can choose to send it instantly or schedule it for a later time using Pabbly Connect. To schedule, click on the calendar icon, select your desired date and time, and confirm your broadcast.
After scheduling, you can monitor the performance of your broadcast. Pabbly provides detailed statistics on how many messages were sent, delivered, and read. This data is crucial for analyzing the effectiveness of your campaigns.
Additionally, if any messages fail to send, you can check the valid and invalid fields and resend them as necessary. This feature ensures that your broadcasts are as effective as possible.
Using Pabbly Connect for WhatsApp broadcasts allows businesses to send personalized messages effectively. By following the steps outlined in this tutorial, you can enhance your communication strategy and improve customer engagement.
