1. Setting Up the Workflow with Enter and From
The first step in integrating Enter with From is to establish a workflow that captures form submissions. This setup ensures that whenever a new form submission occurs, the information is shared with your team on Slack. Start by accessing the Pabi platform and signing in to your account.
Navigate to the Pab Connect dashboard and click on “Create Workflow”. Here, you will name your workflow and select the folder for forms automation. Click on “Create” to proceed.
2. Configuring the Trigger Application: Pabi Webhook
The next step is to configure the trigger application, which will activate the workflow. In this case, choose Pabi as your trigger application and select “Catch Webhook” as the trigger event. Click on the “Connect” button to proceed.
  • Open your form code in a text editor.
  • Replace the existing webhook URL with the copied URL.
  • Save the changes in your form code.
After saving, return to your workflow in Pab Connect. The system will now be waiting for a webhook response to ensure the connection is established correctly.
3. Testing the Setup with Form Submission
To test if the integration between Enter and From is working, submit a test form. Enter your details, such as name, email, and phone number, and click on “Submit”. You should see a confirmation message indicating successful form submission.
Return to the Pab Connect dashboard and check for the captured response. If the setup is correct, you will see the details of your test submission captured in the workflow.
4. Adding Action Application: Slack Notifications
Next, you will add an action application to notify your team via Slack whenever a new form submission occurs. Choose Slack as your action application and select “Send Channel Message” as the action event. Click on “Connect”.
  • Select the channel ID where you want to send notifications.
  • Enter a message template, such as “Hello team, we have received a new lead. Here are the details.”.
  • Map the fields from the form submission to the message.
Once you have configured the message, click on “Save and Send Test Request” to verify if the Slack notification is sent correctly. Check your Slack channel for the message confirming the new lead.
5. Finalizing the Integration Between Enter and From
In conclusion, integrating Enter with From using Pabi allows you to automate notifications for new form submissions effectively. By setting up a workflow in Pab Connect, you ensure that your team stays informed about new leads instantly.
With the steps outlined above, you can easily replicate this integration for your business needs. This automation enhances communication and ensures timely responses to potential leads.
By following this tutorial, you can maximize the efficiency of your workflow with Enter and From. Enjoy seamless integration and improved team collaboration!
