1. Accessing Pabbly Connect for WhatsApp Messaging
To start using Pabbly Connect for sending unlimited WhatsApp messages, first visit pabbly.com/chatflow in your browser. This will direct you to the Pabbly Chatbot homepage, where you can either log in or register for a free trial if you are a new user.
Once logged in, navigate to the Pabbly Chatbot dashboard. Here, you can integrate your WhatsApp number. Make sure your number is linked properly to utilize the broadcasting feature effectively. This setup is crucial for the upcoming steps.
2. Creating a WhatsApp Broadcast in Pabbly Chatbot
After setting up your WhatsApp number, go to the broadcasting section in Pabbly Connect. Here, you can see your existing broadcasts and create a new one. Click on the “Add Broadcast” button to start a new campaign.
  • Choose a name for your broadcast, like “Candle Offer”.
  • Select the audience for your broadcast from your existing contact lists or upload a CSV file.
  • Customize your message type, either using a template or writing a custom message.
Once you have set your audience and message type, proceed to the next step to finalize your broadcast.
3. Uploading CSV Contacts for Broadcasting
If you choose to upload a CSV file for your contact list in Pabbly Connect, ensure that your data is formatted correctly. Download your Google Sheets data as a CSV file and then upload it in the broadcast section.
After uploading, you can filter your audience. You can exclude specific contacts or entire lists if needed. This helps in targeting only the relevant audience for your message, enhancing the effectiveness of your broadcast.
4. Testing Your Broadcast Message
Before sending out the broadcast, it is essential to test your message. In Pabbly Connect, you can send a test message to your WhatsApp number. This ensures that everything appears as intended.
To do this, enter your test WhatsApp number and click on “Send Test Message”. You will receive a confirmation once the test message is sent successfully. Check your WhatsApp to verify the format and content of the message.
5. Scheduling Your WhatsApp Broadcast
Once you have tested your message, you can schedule your broadcast in Pabbly Connect. Decide whether you want to send it immediately or at a future time. If scheduling, select a date and time that suits your campaign.
Remember to enable the automatic retry feature for any contacts that may fail to receive the message. This ensures that your broadcast reaches all intended recipients without additional manual effort.
After confirming all settings, click on “Create Broadcast”. You will see a success message, and your broadcast will be scheduled accordingly.
In this tutorial, we explored how to use Pabbly Connect to send unlimited WhatsApp messages legally. By following these steps, you can effectively utilize Pabbly Chatbot for your marketing campaigns. Enjoy the benefits of seamless communication!
