To start using Pabbly Chatflow for WhatsApp integration, first, open your web browser and navigate to pabbly.com/chatflow. This will take you to the home page of Pabbly Chatflow.
If you are a new user, you can click on the “Sign Up for Free” button to create an account. Existing users should simply sign in. After signing in, you will see all Pabbly applications, where you need to click on “Access Now” for Pabbly Chatflow.
2. Creating a WhatsApp Broadcast in Pabbly Chatflow
Once in Pabbly Chatflow, you will need to create a WhatsApp broadcast to send personalized messages. First, ensure you have connected your WhatsApp number in your Chatflow account. Then, navigate to the broadcast section.
  • Click on “Add Broadcast” to create a new broadcast.
  • Choose “Broadcast Campaign” as the type.
  • Name your broadcast, for example, “New Discount Offer”.
After naming your broadcast, select the contact list you wish to send messages to. You can either add contacts manually or upload them in bulk using a CSV file. Ensure that you have your contact data ready in a Google Sheet to download it as a CSV.
3. Setting Up Your Message Template in Pabbly Chatflow
In Pabbly Chatflow, message templates are essential for sending personalized messages via WhatsApp. You can create a template by navigating to the templates section. Ensure your template is approved by Meta to use it.
To create a new template, click on “Add Template” and draft your message. Use variables in your template for personalization, such as the recipient’s name. This makes your message dynamic and tailored to each customer.
  • Use the variable for the name in your message template.
  • Make sure to save your template once it is approved.
Once your template is ready, you can proceed to the broadcast section to select it for your campaign.
4. Testing and Scheduling Your WhatsApp Broadcast
Before sending your broadcast to all contacts, it’s crucial to test it. In Pabbly Chatflow, you can send a test message to your own WhatsApp number. Enter your contact details and click on “Send Test Message”. You should receive a personalized message confirming that your template works correctly.
After successful testing, you can schedule your broadcast. You have the option to send it immediately or select a future date and time. Make sure to choose a future date to avoid sending it instantly.
  • Select “Yes” to schedule the broadcast for later.
  • Choose a specific date and time for the broadcast.
Click the “Add Broadcast” button to finalize your scheduling. You can track the status of your broadcast, including metrics like sent, delivered, and read messages.
5. Conclusion
In this tutorial, we discussed how to use Pabbly Chatflow for WhatsApp integration. By following the steps outlined, you can easily send personalized messages to your customers, enhancing your communication strategy.
Utilizing Pabbly Chatflow simplifies the process of managing your WhatsApp broadcasts, ensuring a professional and efficient approach to customer engagement.
