To send unlimited bulk WhatsApp messages, you need to access Pabbly Chatflow. Start by visiting pav.com/chatflow in your browser. This will lead you to the Pabbly Chatflow homepage where you can sign up for free or log in if you’re an existing user.
After signing in, you will see the Pabbly apps dashboard. From here, click on the “Access Now” button for Pabbly Chatflow. This is where you can manage your WhatsApp communications and set up broadcasts for your messages.
2. Setting Up Your WhatsApp Broadcast in Pabbly Chatflow
Once in Pabbly Chatflow, navigate to the Broadcast section. This feature allows you to send messages to multiple contacts at once. Before you create a broadcast, ensure you have an approved WhatsApp message template ready.
- Access the Broadcast section from the left sidebar.
- Create a new broadcast by clicking on the “Add Broadcast” button.
- Choose the broadcast type as “Broadcast Campaign”.
After selecting your broadcast type, name your campaign. For example, you can name it “New Flash Sale”. Then, select the contact list you want to send the message to, ensuring all numbers are uploaded into your Pabbly Chatflow account.
3. Uploading Contacts to Pabbly Chatflow
To send messages using Pabbly Chatflow, you need to upload your contacts. If your contact data is in Google Sheets, download it as a CSV file. Then, go to the Contacts section in Pabbly Chatflow.
- Click on “Add Contact” to upload your CSV file.
- Select the option to add contacts in bulk.
- Once uploaded, create a new contact list if necessary.
After uploading, you can refine your audience by excluding contacts you don’t want to message. This customization ensures that your broadcast reaches the right people.
4. Sending WhatsApp Messages Through Pabbly Chatflow
With your contacts uploaded, return to the broadcast setup in Pabbly Chatflow. Choose your pre-approved message template to send out. This is crucial for compliance with WhatsApp’s policies.
Before sending, you can test your broadcast by sending it to your own WhatsApp number. Enter your number and click the “Send Test Message” button to ensure everything looks good. This step is essential to verify that your message appears correctly.
Finally, decide if you want to send the message immediately or schedule it for a later time. If scheduling, select a future date and time, then click the “Add Broadcast” button to finalize your setup.
5. Tracking Your Broadcast Results in Pabbly Chatflow
Once your broadcast is sent, you can track its performance through Pabbly Chatflow. This feature provides insights into how many messages were sent, delivered, read, or failed.
In the Broadcast section, you will find stats for each broadcast, allowing you to see how effective your messaging campaign is. If there are any failures, you can resend the broadcast to those specific contacts easily.
This feedback loop is essential for optimizing your future broadcasts and ensuring maximum engagement with your audience.
Using Pabbly Chatflow, you can efficiently send unlimited bulk WhatsApp messages to your contacts. This tutorial outlined the steps to access Pabbly Chatflow, set up broadcasts, upload contacts, send messages, and track results. Implement these steps to enhance your communication strategy.
