To start sending bulk WhatsApp messages, first, you need to access Pabbly Connect. Open a new tab and type ‘pabbly.com’ in the address bar. This will redirect you to the Pabbly homepage where you can choose the Pabbly Connect option.
Once on the Pabbly homepage, click on the “Sign Up” button if you are a new user. If you already have an account, click on “Sign In”. After signing in, navigate to the Pabbly Connect dashboard to begin the integration process.
2. Connecting Your WhatsApp Number in Pabbly Connect
After accessing Pabbly Connect, the next step is to connect your WhatsApp number. This is essential for sending messages. You can connect your number by scanning a QR code if you are using a WhatsApp Business account.
  • Go to the “Connect” section in the dashboard.
  • Select the option to connect your WhatsApp number.
  • Scan the QR code using your WhatsApp Business app.
After successfully connecting your WhatsApp number, you can explore various features offered by Pabbly Connect to enhance your messaging capabilities.
3. Creating a Contacts List for Bulk Messaging
To send bulk messages, you need to create a contacts list using Pabbly Connect. This list will contain the numbers of your customers to whom you want to send messages.
Follow these steps to create a contacts list:
  • Navigate to the “Contacts” section in the dashboard.
  • Click on “Add Contacts” and choose “Add Bulk Contacts”.
  • Upload your contacts in CSV format with country codes included.
Once the contacts are uploaded, you can manage and segment them for targeted messaging using the features in Pabbly Connect.
4. Creating a Message Template for Broadcast
Now that you have your contacts list, the next step is to create a message template. This template will be used for sending bulk messages via Pabbly Connect to your contacts.
To create a message template, go to the “Templates” section and follow these steps:
  • Click on “Add Template”.
  • Choose the category of your template (e.g., Marketing).
  • Input your message content, including any variables for personalization.
Ensure that your template is approved by WhatsApp before using it for broadcasts, as this is a requirement for sending messages through Pabbly Connect.
5. Sending Broadcast Messages via Pabbly Connect
With your contacts and message template ready, you can now send broadcast messages. This is the final step in using Pabbly Connect to communicate with your customers effectively.
To send a broadcast, follow these steps:
  • Go to the “Broadcast” section in the dashboard.
  • Click on “Add Broadcast” and select your contacts list.
  • Choose the message template you created earlier.
Once you have set everything, click on “Send Broadcast” to deliver your message to all selected contacts. This process ensures that you can efficiently reach out to your customers using Pabbly Connect without any manual effort.
In conclusion, using Pabbly Connect allows you to send unlimited bulk WhatsApp messages effortlessly. By following the steps outlined above, you can effectively promote your business to thousands of customers with just a click.
