To start automating tech news delivery to Discord, access Pabbly Connect by visiting pabbl.com/connect. If you are a new user, click on the “Sign Up for Free” button in the top right corner.
This free trial allows you to explore Pabbly Connect with 100 tasks every month. After signing up, you can choose a subscription plan using a discount code for savings.
Once logged into Pabbly Connect, navigate to the workflow builder. Here, you will set up the trigger and action for your automation.
- Click the “Add Trigger” button.
- Search for “RSS by Pabbly” and select it.
- Choose “New Item in Feed” as the event.
After selecting the event, connect it by entering the feed URL of the tech news source you want to monitor, such as Times of India or The Hindu.
3. Configuring the RSS Feed in Pabbly Connect
To configure the RSS feed, input the URL you obtained from the news source into the feed URL section of Pabbly Connect. Select the filter type as “Default” and click on “Save and Send Test Request”.
This action allows Pabbly Connect to retrieve the latest news items. You will see details like the title, link, date, and description of the news displayed in the response.
Keep in mind that RSS by Pabbly is a polling-based application, meaning it checks for new data at defined intervals. Set your preferred trigger time, which can range from 10 minutes to 24 hours.
4. Sending News to Discord via Pabbly Connect
Next, add a new action step in Pabbly Connect to send the retrieved news to your Discord channel. Search for “Discord” and select it.
- Choose “Send Channel Message” as the event.
- Connect to Discord by authorizing the app.
- Select the channel where you want to send the message.
Once connected, configure the message settings, including the message text and dynamic fields for title and link using the mapping feature in Pabbly Connect.
5. Testing and Activating Your Workflow
After setting everything up in Pabbly Connect, click on “Save and Send Test Request” to test the workflow. If successful, the message will appear in your Discord channel.
Now, your workflow is ready to check for new tech news every 30 minutes and post updates to Discord automatically. You can delete any unnecessary action steps to optimize task usage.
With this setup, Pabbly Connect effectively automates the delivery of tech news to your Discord channel, enhancing your team’s communication and updates.
By using Pabbly Connect, you can effortlessly automate the process of sending tech news to your Discord channel. This integration not only saves time but also keeps your team informed with the latest updates.
