To automate stock alerts on WhatsApp, you first need to access Pabbly Connect. Open your browser and navigate to pabbly.com/connect. If you’re a new user, click on the “Sign Up for Free” option located in the top right corner.
Once you sign up, you can send up to 100 WhatsApp messages for free each month using Pabbly Connect. This allows you to explore its features and decide if you want to upgrade later. After signing up, you will be redirected to the workflow builder, which is crucial for setting up your automation.
2. Creating Workflows in Pabbly Connect
In the workflow builder of Pabbly Connect, you will set up triggers and actions. A trigger is an event that starts the workflow, while an action is what happens as a result. Click on the “Add Trigger” button to begin.
- Search for “RSS by Pabbly” as the trigger application.
- Select “New Item in Feed” as the event.
- Connect by entering the feed URL of your chosen publisher.
After setting up the trigger, you can define how often Pabbly Connect checks for new data, which can range from 10 minutes to 24 hours. For timely updates, set it to 10 minutes.
3. Fetching Data Using RSS Feeds
To receive stock alerts, you need to fetch data from an RSS feed. For this, you can use popular publishers like The Hindu or Times of India. Search for the RSS feed URL of your desired publisher, for example, The Hindu RSS feed.
Copy the feed URL and paste it into the designated field in Pabbly Connect. You will see that Pabbly Connect retrieves the latest news title, link, date, and description. Ensure you save and send a test request to confirm the setup.
- Select the market category for stock updates.
- Set the filter type to default.
This setup allows Pabbly Connect to pull stock market news every 10 minutes, keeping you updated automatically.
After fetching the data, the next step is to send automated WhatsApp messages. For this, you will use Pabbly Chatflow. Click on “Add New Action Step” and search for Pabbly Chatflow.
Choose the event “Send Text Message” and connect your Pabbly Chatflow account by entering your API token. This token can be found in the settings of your Pabbly Chatflow account under API and Webhooks.
- Enter the recipient’s WhatsApp number including the country code.
- Map the message fields to include dynamic data from the RSS feed.
After setting up the message content, you can save and send a test request to ensure that your WhatsApp message is sent successfully. This process allows you to receive timely stock alerts directly on WhatsApp through Pabbly Connect.
5. Conclusion
By following these steps, you can easily automate stock alerts on WhatsApp using Pabbly Connect. This integration not only saves time but also ensures you stay updated with the latest market news.
Utilizing Pabbly Connect allows for seamless integration and automation of various applications, enhancing your productivity and keeping you informed in real-time.
