To start integrating Shopify with Telegram notifications, you first need to access Pabbly Connect. Open your browser and go to the Pabbly Connect landing page.
If you are a new user, click on the “Sign Up for Free” button in the top right corner. This allows you to explore Pabbly Connect with 100 free tasks each month. Existing users can directly access the workflow builder.
2. Setting Up Shopify Trigger in Pabbly Connect
In the Pabbly Connect workflow builder, you will need to set up a trigger for Shopify. Click on the “Add Trigger” button to begin.
  • Search for Shopify and select “Shopify V2”.
  • Choose the event as “New Order”.
  • Click on “Connect” to receive a webhook URL.
Copy the provided webhook URL and navigate to your Shopify settings. Under “Notifications”, find the “Webhooks” section to create a new webhook. Select “Order Creation” as the event, keep the format as JSON, and paste the copied URL. Click on “Save” to establish the connection between Shopify and Pabbly Connect.
3. Capturing Webhook Response from Shopify
After setting up the webhook, you need to test the connection by creating a test order in Shopify. Purchase a product as a test user to generate a new order.
Once the order is placed, return to Pabbly Connect to capture the webhook response. You will see the order details populated in your workflow, confirming the successful connection.
  • Ensure all customer details and product information are correct.
  • This response will be used for sending notifications via Telegram.
Now that you have the response, you can proceed to set up the action step in Pabbly Connect to send notifications to Telegram.
4. Sending Notifications to Telegram via Pabbly Connect
Next, you will set up an action step to send the order details to Telegram. Click on “Add New Action Step” and search for “Telegram Bot”.
Select the event as “Send a Text Message” and click on “Connect”. If you have an existing connection, select it; otherwise, create a new connection by entering the required token from your Telegram bot.
  • Create a new bot in Telegram using BotFather and get the token.
  • Add the bot to your desired group and give it admin access.
After connecting the bot, you will need to map the dynamic order details into your message template. This ensures that every new order triggers a notification with the correct details.
After setting up the message template in Pabbly Connect, you need to finalize the integration. Make sure to map all necessary fields, such as customer name, order value, and shipping location.
Once all mappings are complete, click on “Save and Send Test Request” to verify that the message is sent to your Telegram group successfully. Check your Telegram to confirm the order alert appears as expected.
This automation allows your team to receive real-time notifications for every new order placed on Shopify, enhancing operational efficiency and response time.
In this tutorial, we explored how to integrate Shopify with Telegram notifications using Pabbly Connect. This automation streamlines order notifications, ensuring your team stays informed in real-time.
