1. Accessing Pabbly Connect for Bulk Messaging
To send salon discounts effectively, first access Pabbly Connect. Open your browser and navigate to pabbly.com/chatflow. This will take you to the Pabbly Chat Flow homepage.
If you are a new user, click on ‘Sign Up for Free’ to create an account. Existing users can simply log in. Once logged in, you will see options to access various Pabbly applications, including Pabbly Connect.
2. Setting Up Pabbly Chat Flow for Discounts
After accessing Pabbly Connect, go to the “All Pabbly Apps” window. Here, you can find Pabbly Chat Flow. Click on ‘Access Now’ to enter the dashboard. You will need to connect your WhatsApp number to send messages.
  • Click on ‘Add Broadcast’.
  • Select ‘Broadcast Campaign’ as the type.
  • Name your campaign, e.g., ‘Salon Offer’.
Next, select your audience. You can either choose an existing contact list or upload a CSV file if your data is stored elsewhere, like Google Sheets. This step is crucial for targeting your customers effectively.
3. Creating Your Message Template
With Pabbly Connect, you can create a personalized message template. This template will include a variable for the customer’s name, making it more engaging. Ensure your template is approved by Meta for automated messaging.
To do this, go to the broadcast section and select your template. You can add the name variable to dynamically personalize each message. This helps in creating a connection with your clients, making your offers more appealing.
4. Sending Your Broadcast Message
Once your template is set, you can proceed to send your broadcast using Pabbly Connect. Click on ‘Send Test Message’ to verify that everything is working correctly. Enter your WhatsApp number to receive the test message.
After confirming the test message, you can schedule your broadcast. Choose whether to send it immediately or at a later date. Make sure to select a future date to avoid sending it at the wrong time.
  • Select ‘No’ for immediate sending or ‘Yes’ to schedule.
  • Set the date and time for the broadcast.
  • Enable automatic retries for failed contacts.
Once scheduled, you can monitor the broadcast statistics, including sent, delivered, and read messages, ensuring you track the success of your campaign.
5. Conclusion
Using Pabbly Connect to send salon discounts and beauty offers in bulk is a straightforward process. By following these steps, you can effectively reach your customers and enhance your marketing efforts.
Remember to utilize the features of Pabbly Connect and Pabbly Chat Flow to maximize your outreach and engagement.
