To begin integrating Telegram with Razorpay, you need to access Pabbly Connect. If you’re a new user, navigate to pabbl.com/connect in your browser. This will take you to the landing page of Pabbly Connect.
In the top right corner, you’ll see the option to “Sign up for free.” Click this to create an account and get started with 100 free tasks every month. This allows you to explore Pabbly Connect and set up your automation without any cost.
2. Setting Up Trigger for Razorpay
Once you’re logged into Pabbly Connect, you need to set up the trigger. Click on the “Add Trigger” button and select Razorpay as the application. For the event, choose “Payment Capture” to notify when a payment is received.
  • Open your Razorpay dashboard.
  • Navigate to Account and Settings.
  • Select Webhooks and click on “Add New Webhook”.
Paste the webhook URL provided by Pabbly Connect into the Razorpay Webhook settings. This establishes a connection between Razorpay and Pabbly Connect, allowing you to capture payment data.
3. Capturing Webhook Response
After setting up the webhook, you need to test it by creating a payment. Go back to Razorpay, select a product, and complete a test payment. This will generate a webhook response that Pabbly Connect will capture.
Once the payment is completed, Pabbly Connect will display the webhook response confirming that the connection is successful. This step is crucial as it verifies that Razorpay and Pabbly Connect are communicating correctly.
4. Setting Up Action for Telegram
Now, it’s time to set up the action step in Pabbly Connect. Click on “Add New Action Step” and select Telegram Bot as the application. Choose the event “Send a Text Message” to notify your team of new payments.
  • Connect your Telegram bot using the BotFather.
  • Copy the API token provided by BotFather and paste it into Pabbly Connect.
  • Add your bot to the Telegram group where notifications will be sent.
After successfully connecting, you will need to provide the chat ID of the group. This ensures that all messages are sent to the correct location. Finally, map the necessary fields for the message content, which could include customer details and order information.
5. Testing the Integration
After setting everything up, it’s time to test the integration. Click on “Save and Send Test Request” in Pabbly Connect. This will send a test message to your Telegram group confirming that the automation is working as intended.
Once you receive the message, your integration is complete! Now, every time a payment is captured in Razorpay, your team will receive a notification in Telegram instantly. This automation will save you time and ensure that your team is always updated.
Integrating Telegram with Razorpay using Pabbly Connect allows for seamless notifications about new payments. This setup enhances communication and streamlines your workflow effectively.
